Flexible netflow on Cat 9300/9500 on L3 vlan interface
carl_townshend
Hi All
I have a question about flexible netflow.
On our Catalyst 9500 switch we want to send netflow to our collector (whatsup gold)
If we want to collect info from a layer 3 vlan, which is the correct config?
vlan configuration 126
ip flow monitor WUG-NETFLOW-IN input
ip flow monitor WUG-NETFLOW-OUT output
or
interface vlan 126
Enes Simnica
Level 5
Level 5
Hello @carl_townshend.
To collect NetFlow data from a Layer 3 VLAN interface on your Catalyst 9500 switch, you should configure the flow monitor on the interface itself, not within the VLAN configuration mode. Here is the correct configuration:
interface vlan 126
So, the correct configuration is the second option
This configuration ensures that the NetFlow data is captured as it enters and leaves the Layer 3 VLAN interface and is sent to your collector (WhatsUp Gold). Make sure you have already defined the WUG-NETFLOW-IN and WUG-NETFLOW-OUT flow monitors and their associated flow records and exporters in the global configuration.
Also, here’s a quick example of how you might define these:
flow record WUG-RECORD
 match ipv4 source address
 match ipv4 destination address
 collect interface input
 collect counter bytes
 collect counter packets
flow exporter WUG-EXPORTER
 destination <collector-ip>
 transport udp 2055
 record WUG-RECORD
 record WUG-RECORD
I hope this information proves useful!
E.S
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Enes Simnica
Level 5
Level 5
interface vlan 126
 transport udp 2055
 record WUG-RECORD
 record WUG-RECORD
E.S
more Cisco?!
more Gym?!
Hi Enes
Thanks for that, we already have the rest of it configured, its just the L3 vlan bit.
So when would we use the vlan configuration part?
Enes Simnica
Level 5
Level 5
hello @carl_townshend
ur welcome!
About the question: when to use the vlan config part:
The VLAN configuration part for NetFlow is used when you want to monitor traffic on a Layer 2 VLAN interface or a Layer 3 VLAN interface but at a specific level of granularity. Here's when and why you would use it:
When to Use VLAN Configuration for NetFlow
  1. Layer 2 VLAN Interfaces:
    • Traffic Visibility: If you want to monitor traffic within a VLAN at Layer 2 (without routing), you can apply the NetFlow monitor to the VLAN interface.
    • Use Case: Useful in scenarios where you want to track intra-VLAN traffic or traffic between VLANs that are routed on another device.
  2. Layer 3 VLAN Interfaces (SVI - Switched Virtual Interfaces):
    • Routing Traffic: When you want to monitor traffic routed to or from a Layer 3 VLAN interface (SVI) on a switch.
    • Granularity: Allows you to monitor traffic that is routed and processed by the switch, providing visibility into the traffic as it enters or exits the VLAN.
Also the summary for this situation I believe is this: VLAN Configuration: Use this when you need to monitor traffic on a Layer 2 VLAN or Layer 3 VLAN interface directly. and, Interface Configuration: Apply NetFlow to physical interfaces or routed VLAN interfaces for more granular control and detailed monitoring.
So I'm sure that understanding the traffic flow and what you want to monitor will help you decide whether to use VLAN configuration or interface-level configuration.
Hope this will help!
E.S
more Cisco?!
more Gym?!
