Formating flash from Rommon mode>
framedrelay
I recently upgraded my router memory to 32 MB, however it seems it doesnt take it.
Kindly help.....
rommon 8 > set IP_ADDRESS=192.168.2.38
usage: set
rommon 9 > IP_ADDRESS=192.168.2.38
rommon 10 > IP_SUBNET_MASK=255.255.255.0
rommon 11 > DEFAULT_GATEWAY=192.168.2.1
rommon 12 > TFTP_SERVER=192.168.2.222
rommon 13 > TFTP_FILE=c2600-is-mz.123-26.bin
rommon 14 > tftpdnld
IP_ADDRESS: 192.168.2.38
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.2.1
TFTP_SERVER: 192.168.2.222
TFTP_FILE: c2600-is-mz.123-26.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
get_man_dev: Unknown device - probably NOT formatted.
unknown flash device - mandev code = 0xffff
cannot read flash info
TFTP: Error, insufficient flash installed to load image.
TFTP: Operation terminated.
rommon 15 >
rommon 15 > meminfo
Main memory size: 24 MB.
Available main memory starts at 0x10000, size 24512KB
IO (packet) memory size: 25 percent of main memory.
NVRAM size: 32KB
rommon 16 >
rommon 16 > dir flash:
getdevnum warning: device "flash" has size of zero
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "flash:"
rommon 17 >
Jenni.
6 Replies 6
framedrelay
I myself installed the memory (Flash), not sure if its correctly went in :(
rommon 3 > IP_ADDRESS=192.168.2.38
rommon 4 > IP_ADDRESS=192.168.2.211
rommon 5 > IP_SUBNET_MASK=255.255.255.0
rommon 6 > DEFAULT_GATEWAY=192.168.2.1
rommon 7 > TFTP_SERVER=192.168.2.222
rommon 8 > TFTP_FILE=c2600-is-mz.123-26.bin
rommon 9 > tftpdnld
IP_ADDRESS: 192.168.2.211
rommon 10 >
Peter_Kurdziel
You might have the wrong part number.
When we buy Flash, we have to check for PART number as well. I only checked for 2600 FLASH memory. How can i confirm that. Kindly help -
Jenn!
what was inside this router was -
SMART SMT 732C2000AS 12 PCF 199071523
where can i see ? Iam not sure
I tired loading the previous flash, its giving thsi error
rommon 1 > dir flash:
device does not contain a valid magic number
rommon 2 >
as usual on this forum nothing gets resolved.
My flash came with the router and its doing the error
No what?
