Forwarding performance
ibrahim_commu1
Frequent Visitor
Frequent Visitor
I want to know the difference between forwarding rate bandwidth, forwarding performance and forwarding rate
for example WS-C3650-24TS-S
Performance Switching capacity : 88 Gbps Forwarding performance : 65.47 Mpps
Philip D'Ath
Meraki Community All-Star
On the whole, it is a marketing number indicating the maximum performance you can possibly achieve.
Worry more about getting the quantity and type of ports you need.  It will forward at line rate.
The forwarding bandwidth is measured in Gb/s.  The forwarding rate is measured in packets per second.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Forwarding bandwidth, is usually the capacity of the fabric.  To avoid queuing traffic, you need 2x all your port "bandwidths".  To provide sufficient PPS, for minimum size Ethernet, you need 1.488 Mpps per gig, for all your port bandwidths. (E.g. 24 [duplex] gig ports need 48 Gbps fabric bandwidth and 35.712 Mpps.)
Sometimes spec sheets will list higher values, than you need (or the device can use) but that's often because the same fabric and forwarding hardware might be used in a larger capacity device.  For example, the difference between a 24 and 48 port device, internally, might only be the number of edge ports that connect to the "innards" of the device.
Current Enterprise class switches are often line rate or wire speed capable (i.e. they can run every port at full rate, concurrently).  However that's not always true with older switches, e.g. 3560G.
