Forwarding ports trough specific interface
alister9000
Community Member
Hi everyone,
Im trying to configure some ports to be forwarded out to a serial interface, we have installed voip phones (not cisco) and i want them to use only the serial port.
this is the sh run output. needless to say i have erased some sentitive information:
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description  inside
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description Outside
ip address 1.1.1.1 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
description T1
no ip address
encapsulation frame-relay IETF
interface Serial0/0/0.500 point-to-point
ip address 2.2.2.2 255.255.255.252
frame-relay interface-dlci 500
ip default-gateway 1.1.1.1
ip forward-protocol nd
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 102 permit tcp any range 4444 4446 any
access-list 102 permit udp any range 30000 38000 any
access-list 102 permit udp any eq 5060 any eq 5060
access-list 102 permit udp any eq 6060 any eq 6060
i know that im missing the ip nat statements but i dont want to do it right now as it will interfere with everyones job if it doesnt work. i dont know if the access lists will work can anyone help me with it?
thanks
Reza Sharifi
The way your router is currently configured, everything will go out using interface GigabitEthernet0/1
If you want some traffic to go out using theGigabitEthernet0/1 interface and some traffic using GigabitEthernet0/1 than you need to configure PBR.
Have a look at this link for info and example:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/unicast/configuration/guide/l3_pbr.html
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
i am using a cisco 1921 router and the command to enable pbr does not exists...i guess its not supported (?), is there any other way i can do this ?
