Frame size !
fb_webuser
Level 6
Level 6
What’s the maximum frame size of Gigabit Ethernet?
Posted by WebUser Hossein Lotfi
Latchum Naidu
Gigabit Ethernet maintains the minimum and maximum frame sizes of Ethernet. Since, Gigabit Ethernet is 10 times faster than Fast Ethernet, to maintain the same slot size, maximum cable length would have to be reduced to about 10 meters, which is not very useful. Instead, Gigabit Ethernet uses a bigger slot size of 512 bytes. To maintain compatibility with Ethernet, the minimum frame size is not increased, but the "carrier event" is extended. If the frame is shorter than 512 bytes, then it is padded with extension symbols. These are special symbols, which cannot occur in the payload. This process is called Carrier Extension.
Please rate the helpfull posts.
Naidu.
flokki123
Level 3
Level 3
hi,
the frame size is defined by the ethernet standard and is independent of the speed.
the min. frame size of ethernet is 64bytes and the max. is 1518(1522 with a vlan tag).
every frame bigger than 1522 is considered a jumbo frame.
regards,
florian
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained  within this   posting without consideration and with the reader's  understanding that   there's no implied or expressed suitability or  fitness for any  purpose.  Information provided is for informational  purposes only and  should not  be construed as rendering professional  advice of any kind.  Usage of this  posting's information is solely at  reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
If the equipment supports "jumbo" frames, usually about 9 KB.
