getting error of invalid input for switchport trunk
GuriSingh
i am getting this error of invalid input for switchport in config terminal of switchport fa0/0 connected router
6 Replies 6
@GuriSingh
 This is a layer3 port and does not accept layer2 features
is there any way I can convert it into a switchport or enable the data transfer with the main campus
Not possible to convert. Is It a switch IOS or Router IOS?
 Gns3 is very bad for layer2.
this one is a router IOS
That´s should be the problem. As a router, you dont have layer2 feature.
You need to play with L2 IOU or you can try EVE, which is much better than GNS3 and also free
there is L2 IOU
check google for this image
MHM
