Getting RSSI from telnet interface
dvaldes011
Community Member
Hello everybody,
How can I ask RSSI equipment using telnet interface? Can you show an example with screenshoots or sth ? Thanks
6 Replies 6
Philip D'Ath
Meraki Community All-Star
Access point?  Router?  3G interface?
Can you at least give us a hint as to what kind of Cisco device this is, and what kind of interface you are interested in.
Sry uys, you are right.
I mounted this infraestructure (see image). So I need to get RSSI from AP3502, but using command snmpget, that is my question, the way to use snmpget, do you got an example please ?
need more information as Philip requested,If I were to guess this is Cisco WLC environment
you can check RSSI in in WLC gui in monitor section and going in to each clients or by executing "show client detail clientmac" in cli
on autonomous APs you can check RSSI by executing
"show dot11 associations MAC"
There are many other ways aswell
***Please rate all the useful posts***
-Prabath
dvaldes011
Community Member
