Giant Errors cisco 7609
Hi Team,
I have a query about "Giant errors" on cisco 7609 router.The connectivity is between two cisco 7609 routers
What could be the issue ?
Note: I have "IP MTU 1500" configured under this interface .
I only see the giant errors are increasing show below.
MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 3/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is on
Clock mode is auto
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d21h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4636
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10153000 bits/sec, 2486 packets/sec
5 minute output rate 11981000 bits/sec, 2749 packets/sec
L2 Switched: ucast: 158153 pkt, 45312418 bytes - mcast: 121285 pkt, 9913575 bytes
L3 in Switched: ucast: 1016534837 pkt, 514921445490 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 1393453588 pkt, 1067146490148 bytes mcast: 0 pkt, 0 bytes
1016782822 packets input, 514964559038 bytes, 0 no buffer
Received 125475 broadcasts (0 IP multicasts)
0 runts, 87294 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
1393597184 packets output, 1078270648027 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Yuvaraj Karvekar
0 Replies 0
