gigabit ethernet
ichavarria
What is the model of gigabit ethernet that I have to install into a cisco switch WS2960G-24-tl-c
Leo Laohoo
Any model. The appliance will be able to negotiate the duplex and speed settings to your machines Network Interface Card (NIC) whether it's 10, 100 or 1000 Gb. Just make sure it's not Novell. :)
Giuseppe Larosa
Hello Indalacio,
if you mean what type of optical transceiver to use on the uplinks, the device can use SFP.
The exact type to use depends on what type is used at the other end of the fiber (two fibers) link.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/hardware/quick/guide/9368.pdf
chapter Connect to switch ports
for details about SFP modules see
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
Hope to help
Giuseppe
