Gigabit port throughput limits
aspodinets
Hi everyone!
I run a network powered by 3750G. Network consists of several points of presence with several switches in each. POPs are xconnected with fibers.
I hvanoticed that some fiber ports start to loose packets on low bitrate (100M). Closer inspection showed that packet rate is much bigger (40000 Pps).
I found it accaptable since nature of data is multicast with packets of 500-700 bytes average.
For most of ports packet loss starts when PPs reaches ~83000. While there is a port where I see packet loss on 40k in each direction.
So I have two questions:
1. Is it a practical top of switch port throughput ? Looks weird when switch looses packets on 100Mbps utilisation;
2. My understanding is that Tx and Rx are woring with its own buffers each. Thus overflow of one of them shouldn't impact the other. But practically I see that Tx and Rx packet rates are affecting buffer in total.
I'm starting to feel like something is misconfigured. Please advice.
Alex.
H2H
aspodinets
Here is the summary of the port for #2:
show interfaces gi1/0/25 summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* GigabitEthernet1/0/25 0 0 0 1676612 44711000 36148 74959000 35788 0
