GLBP GLBP-4-BADAUTH
Siemens_SWP
I have two 4500 switches running GLBP and I recive some strange log messages. I can't find out what the problem is. Hope you could help:
s-aala8-24-1-core2#sh run inter vlan 120
Building configuration...
Current configuration : 451 bytes
interface Vlan120
description ** Printers **
ip address 149.212.19.243 255.255.255.240 secondary
ip address 149.212.19.163 255.255.255.224
ip helper-address 149.212.3.228
no ip redirects
no ip unreachables
no ip proxy-arp
glbp 1 ip 149.212.19.161
glbp 1 ip 149.212.19.241 secondary
glbp 1 timers msec 250 msec 750
glbp 1 priority 150
glbp 1 preempt delay minimum 180
glbp 1 authentication md5 key-string 7 113A0E353043093C253F3F2C
end
s-aala0-1-1-core# sh run inter vlan 120
interface Vlan120
ip address 149.212.19.242 255.255.255.240 secondary
ip address 149.212.19.162 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
glbp 1 priority 150
end
Sep 15 13:09:47.308 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 13:57:09.645 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 13:59:07.582 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 14:01:16.851 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 14:02:01.264 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 14:02:33.592 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 14:03:08.872 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
Sep 15 14:04:32.712 CEST: %GLBP-4-BADAUTH: Bad authentication received from 149.212.19.162, group 1
The switches is running IOS Version 12.2(46)SG (Enterprice)
Mikkel
5 Replies 5
Lucien Avramov
Level 10
Level 10
%GLBP-4-BADAUTH : Bad authentication received from [IP_address], group [dec]
Explanation Two routers participating in a Gateway Load Balancing Protocol group disagree on the valid authentication string.
Recommended Action Use the glbp authentication interface command to repair the GLBP authentication discrepancy between the local system and the one whose IP address is reported.
Thanks for the reply.
I know. The problem is that I have tryed that many times. But it don't seems to help. Could there be any other reason for this problem?
It is not only on VL120 there is a problem, but on every VL on the two switches.
Best regards
Mikkel
Joseph W. Doherty
You didn't note whether GLBP status seems to be correct for this group.
You might first try re-entering GLBP key-string, as clear text, on both 4500s.
e.g.
glbp 1 authentication md5 key-string SwPG1bPAuthH
You might confirm that this VLAN isn't seeing a GLBP hello from any other VLAN. I.e., confirm there isn't any possible leakage between VLANs.
Oki I will try that, and tell you later if it works.
Just one question:
What do you mean: You might confirm that this VLAN isn't seeing a GLBP hello from any other VLAN. I.e., confirm there isn't any possible leakage between VLANs.
And how will I do that?
"What do you mean: You might confirm that this VLAN isn't seeing a GLBP hello from any other VLAN. I.e., confirm there isn't any possible leakage between VLANs. "
I mean you should verify your topology to insure that VLANs and subnets don't (unexpectedly) share the same wire. Unlikely, but I see you're using secondary addressing which is unusual when you have VLAN support. (I.e. normally would expect your two subnets to be in their own VLANs.)
"And how will I do that? "
Perhaps activate debug for GLBP and see what GLBP packets you're receiving. Confirm they're from the neighbor you expect.
