GLBP weighting help
Andrew White
Level 2
Level 2
Can someone explain the GLBP weighting option, I'm struggling with this one.  On my lab set up I have 3 routers and this is all working below, but want to practise using weighting.
R1
track 1 interface FastEthernet0/1 line-protocol
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
glbp 1 ip 192.168.1.1
glbp 1 priority 105
glbp 1 preempt
glbp 1 weighting track 1
R2
ip address 192.168.1.3 255.255.255.0
duplex auto
speed auto
glbp 1 priority 104
glbp 1 preempt
R3
ip address 192.168.1.4 255.255.255.0
duplex auto
speed auto
glbp 1 priority 103
glbp 1 preempt
So what would it mean it I was to use this on R1:
glbp 1 weighting 100 lower 90 upper 95 (does 100 have to match the 105 prioroity on R1?)
glbp 1 weighting track 1 decrement 20
From what I can see if Fa 0/1 was to go down the GLBP weight would be 105 - 20 = 85 and will no longer be the AVG and AVF and R2 will take over?  If the weight is 95 or above it will become an AVF again and the AVG?
7 Replies 7
InayathUlla Sharieff
Hi Adrew,
The example/Configuration part will help you to understand what you are looking for in the blow link;
http://blog.ine.com/2008/04/24/glbp-explained/
if this doesnt help then please let us know and we will try to help you further.
Inayath
Julio Carvajal
Hello Andrew,
I would say your idea is good but you are wrong in something:
The Weigth attribute will determine only if a router can be an active Virtual forwarder, nothing relatedo to the AVG status.
Based on that we could said that weighting will determine only the capacity that a router has in the GLBP cluster to forward traffic.
In this case we are seing that the weight value is 100 and if the tracking object goes down or fails the weigth will be 80. whitch is lower than 90 so this router will be marked as a non-valid AVF... and finally it will be used back as a AVF until reaches the weighting of 95
The GLBP weight is different than the priority ( this is used to determine the Active virtual gateway)
Julio
Remember to rate all of the helpful posts
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thanks, I thought all routers in the GLBP cluster were AVF's and the AVG just assigns different virtual mac addresses when a host does an arp lookup?
Hi Andrew,
As far the concept goes you are right. In the cluster one of the router will be AVG and other are AVF.
Host request the ARP--> AVG gets it and assign one of the AVF mac address. (It does RR load balancing amount AVF).
Inayath
*Plz rate the usefull posts.
Hello Inayath,
Being a internal Cisco person with access to specifications, could you perhaps also shed more light on this thread which is strongly related to this one? Thank you!
https://supportforums.cisco.com/message/3821065#3821065
In particular, we were discussing how exactly are the AVFs selected from a group of GLBP-enabled routers. Their priorities nor weights do not appear to bear any relevance.
Best regards,
Peter
Good question Peter I know it is supposed to use round-robin but when I have debugged it didn't seem to follow this process.
Quick question guys, so If I have 3 routers in the GLBP cluster 1 will be the AVG and 2 will be AVF's, does this mean the AVG doesn't forward traffic?
Hello Andy,
In reality, one of the routers will be elected AVG and all three routers will be elected AVFs. One of these routers will hence be both AVG and AVF.
Best regards,
Peter
