Bookmark
Subscribe
3306
GLC-LX-SM-RGD to GLC-LH-SM Compatibility
praetoleiad
will it work if i have a switch-to-switch connection with GLC-LX-SM-RGD on one end and GLC-LH-SM on the other end?
nkarthikeyan
Level 7
Level 7
Yes you can use that in the compatible device models. Because the rugged SFP is supported only through the specific device models. Since rugged and LH sfp you have used is operating in the same wavelength it should work. But the device compatability is much important in your case.
Rugged SFP:
http://hkinglong.en.alibaba.com/product/340734342-209942783/GLC_LX_SM_RGD_1000Mbps_Single_Mode_Rugged_SFP.html
Long Haul - LH SFP:
http://www.alibaba.com/product-gs/439493740/Cisco_GLC_LH_SM_1_x.html
Please do rate if the given information helps.
By
Karthik
CSCO10540325
No it does not work for this case. Please be concerete. one site LX one Site LH does not work.
