GNS3 3745 - No Switch Connectivity
marksargent
Hi All,
am using GNS3, and have the 16port switching module. I have created a PC instance and connecting to f/0/0 which is a layer 3 port, I can connect via layer 3 IPs. I then reconfigured and connected the PC instance via a layer 2 port f2/0 which is part of the 16port switch module. All 16 ports are by default in vlan 1. I assigned an IP of 10.1.9.1/24 to the VLAN and gave the PC 10.1.9.2/24. I cannot ping and I cannot even ping 10.1.9.1, the VLAN 1 IP. Have I missed something? Thanks.
Mark Sargent
Router#sh ver
Cisco IOS Software, 3700 Software (C3745-SPSERVICESK9-M), Version 12.4(19), RELEASE SOFTWARE (fc1)
Router#ping 10.1.9.1
Sending 5, 100-byte ICMP Echos to 10.1.9.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.9.1                -   c402.2668.0000  ARPA   Vlan1
Router#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES manual up                    up
Serial0/0                  unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
Serial0/1                  unassigned      YES unset  administratively down down
FastEthernet2/0            unassigned      YES unset  up                    down
FastEthernet2/1            unassigned      YES unset  up                    down
FastEthernet2/2            unassigned      YES unset  up                    down
FastEthernet2/3            unassigned      YES unset  up                    down
FastEthernet2/4            unassigned      YES unset  up                    down
FastEthernet2/5            unassigned      YES unset  up                    down
FastEthernet2/6            unassigned      YES unset  up                    down
FastEthernet2/7            unassigned      YES unset  up                    down
FastEthernet2/8            unassigned      YES unset  up                    down
FastEthernet2/9            unassigned      YES unset  up                    down
FastEthernet2/10           unassigned      YES unset  up                    down
FastEthernet2/11           unassigned      YES unset  up                    down
FastEthernet2/12           unassigned      YES unset  up                    down
FastEthernet2/13           unassigned      YES unset  up                    down
FastEthernet2/14           unassigned      YES unset  up                    down
FastEthernet2/15           unassigned      YES unset  up                    down
Vlan1                      10.1.9.1        YES manual up                    down
Router#sh int f2/0 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: none
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
VLAN Name                             Status    Ports
1    default                          active    Fa2/0, Fa2/1, Fa2/2, Fa2/3
                                                Fa2/4, Fa2/5, Fa2/6, Fa2/7
                                                Fa2/8, Fa2/9, Fa2/10, Fa2/11
                                                Fa2/12, Fa2/13, Fa2/14, Fa2/15
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Router#sh int vlan 1
Vlan1 is up, line protocol is down
  Hardware is EtherSVI, address is c402.2668.0000 (bia c402.2668.0000)
  Internet address is 10.1.9.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     12 packets output, 890 bytes, 0 underruns
     0 output errors, 1 interface resets
     0 unknown protocol drops
you definitely need to change cable
apart this i would configure the interface in this way:
int fa2/0
sw mo acc
sw acc vla 1
sh
no sh
end
wr
Take Care
Alessio
8 Replies 8
marksargent
"Operational Mode: down" worries me. Shouldn't is say "static access"? Thanks.
Mark Sargent
yes it should and that's also why the SVI is down.Can you post your GNS3 file.
Regards.
Alain.
Regards.
Alain.
Do you mean the topology file for GNS3 for this lab? Thanks.
Mark
int fa2/0
sw mo acc
sw acc vla 1
sh
no sh
end
wr
Take Care
Alessio
int fa2/0
sw mo acc
sw acc vla 1
sh
no sh
end
wr
Take Care
Alessio
EDIT: Well, the below changes seemed to work as I can now ping 10.1.9.1 which I couldn't before. Thanks.
Mark
Change the cable? In a GNS3 lab, you're kidding, yes?
Why do I need to tell the router f2/0 is in access mode as it shows in the initial output i posted that it is. It also shows that f2/0 is assigned to vlan 1, which is default by the way...
what is,
"sh"
"no sh"
The interface shows as up already...
Thanks.
Mark
purohit_810
Level 5
Level 5
set speed and duplex - it will bring it up interface and once vlan has active interface, vlan protocol status will be up.
conf t
vlan {vlan id}
   name
int {interface #}
switchport access vlan {vlan id}
speed 100
duplex f
shut
no shut
this config will be at switch side.
OMG!! I had same issue where the directly connected physical interface was in up/down state.  it drove me crazy because I knew there was nothing special about the configurations but could not understand why. Vlan 10 was up/up and I had interfaces in vlan 10.
As for me, I had created a another vlan just to get away from default vlan 1. I started switching back and forth to see what works.  I changed the native vlan's but no change back and forth from vlan 10 and 1.  i checked with a known working network with real equipment and it was working there - it drove me nut coz I could not it anywhere.
And all I was trying to do was to create access list labs - how frustrating?
I then noticed that on the routed interface (router side) duplex was half / 10.  On switch is was full.  I changed the router side to full / 100 (this side resets itself when you make a change.  Did the same on  switch; no change.  I reset the interface on switch side and the interface came up/up and in trunk mode as I configured it.
If you are currently using Cisco 3725 IOS all I had done and solved this terrible situation is removing the second slot of NM-16ESW.
Then it started to ping from PC to the correctly configured Vlan switch port.
Hope, it will be useful !
