04-06-2018 07:50 AM - edited 03-08-2019 02:33 PM
Im testing out VIRL images on gns3 so my first test was to have 2 routers on the same subnet and have them ping each other. For some reason they wont ping each other but when i place two 2691 routers with the same configs as the other routers they ping perfectly fine. Below is the config for the CiscoIOSv15.6(2)T Routers the only difference is the ip address.
Escape character is '^]'.
sh run
Building configuration...
Current configuration : 3549 bytes
! Last configuration change at 14:41:50 UTC Fri Apr 6 2018
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp log mismatch duplex
ip tcp synwait-time 5
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 10.0.0.1 255.255.255.240
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/4
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/5
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/6
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/7
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
transport input none
no scheduler allocate
end
