Going loopy over loopback!
3iron
Hi All,
Could I ask a kind soul to help clarify the use of loopback. I've been reading the link below and it provides and example of how loopback could be used.
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/routconf.html#pgfId-1071327
"The loopback interface in this sample configuration is used to support Network Address Translation (NAT) on the virtual-template interface. This configuration example shows the loopback interface configured on the gigabit ethernet interface with an IP address of 200.200.100.1/24, which acts as a static IP address. The loopback interface points back to virtual-template1, which has a negotiated IP address."
interface loopback 0
ip address 200.200.100.1 255.255.255.0 (static IP address)
ip nat outside
interface Virtual-Template1
ip unnumbered loopback0
no ip directed-broadcast
ip nat outside
In this scenario is the loopback interface used to act as a point of routing from the outside NAT into the single loopback address?
is this a primary function of loopback?
Thanks a lot
Mark Malone
There mainly used for management reasons as the primary function as its always up/up if your polling a routers loopback and if thats gone down chances are the whole router is but  they can be used with features like NAT  as well
Configure an IPv4 Loopback Interface
Another common configuration of Cisco IOS routers is enabling a loopback interface.
The loopback interface is a logical interface internal to the router. It is not assigned to a physical port and can therefore never be connected to any other device. It is considered a software interface that is automatically placed in an “up/up” state, as long as the router is functioning.
The loopback interface is useful in testing and managing a Cisco IOS device because it ensures that at least one interface will always be available. For example, it can be used for testing purposes, such as testing internal routing processes, by emulating networks behind the router.
Additionally, the IPv4 address assigned to the loopback interface can be significant to processes on the router that use an interface IPv4 address for identification purposes, such as the Open Shortest Path First (OSPF) routing process. By enabling a loopback interface, the router will use the always available loopback interface address for identification, rather than an IP address assigned to a physical port that may go down.
Mark Malone
Hi Mark - thanks that has helped a lot
