GRE(mGRE) and VRF configuration problem
King Jin
Hey guys,
I meet a problem about setting tunnels with VRF between 6509 and 4507. I created VRF instance/Tunnels on both switches, both tunnels are up but only 6509 can see 4507 via its tunnel, 4507 cannot see 6508 via its tunnel, so i cannot see eigrp nei at 4507 for its VRF. 4507 and 6509 are connected directly via L3-P2P. I do not meet this issue when setting tunnels between 6509s because i can use NHRP. Below shows you the configuration.
6509 Configuration:
6509#sh run int tu8
Building configuration...
Current configuration : 424 bytes
interface Tunnel8
 description mGRE
ip vrf forwarding test
 ip address 172.23.12.129 255.255.255.224
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1476
 ip authentication mode eigrp 1 md5
 ip authentication key-chain eigrp 1 EIGRP-KEY
 ip nhrp map multicast dynamic
 ip nhrp network-id 8
 no ip split-horizon eigrp 1
 cdp enable
 tunnel source Loopback108
 tunnel mode gre multipoint
end
6509#sh run int lo108
Current configuration : 113 bytes
interface Loopback108
 description mGRE Source Interface
 ip address 10.143.0.218 255.255.255.255
end
6509#
6509#sh ip vrf int test
Interface              IP-Address      VRF                              Protocol
Vl1033                 172.23.12.228   test                          up
Tu8                    172.23.12.129   test                          up
6509#
 address-family ipv4 vrf test
  redistribute static metric 2048 1900 255 1 1500
  network 172.23.12.0 0.0.0.255
  auto-summary
  autonomous-system 1
 exit-address-family
6509#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
4507
                 Tunnel8           172          R S I     WS-C4507R Tunnel8
4507 configuration:
4507#sh run int tu8
Current configuration : 353 bytes
interface Tunnel8
 ip address 172.23.12.132 255.255.255.224
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1476
 cdp enable
 tunnel destination 10.143.0.218
4507#sh run int lo108
Current configuration : 95 bytes
  ip address 10.143.0.224 255.255.255.255
end
4507#sh ip vrf int test
Vl1033                 172.23.12.231   test                          up
Tu8                    172.23.12.132   test                          up
4507#
 address-family ipv4 vrf DMZ-PKG autonomous-system 1
  passive-interface default
  no passive-interface Tunnel8
 exit-address-family
4507#sh ip eigrp vrf test neighbors
EIGRP-IPv4 Neighbors for AS(1) VRF(test)
(nothing display here because 4507 cannot see its nei 6509 via its tunnel 8)
System image file is "bootflash:cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin"
Any ideas on this issue?
King Jin
BTW, from 6509, i can see the 4507 IP 172.23.12.132 from eigrp nei information, but the uptime cannot last over 1 minute, after 1 min, the uptime will back to zero and start again.
6509#show ip eigrp vrf test neighbors
IP-EIGRP neighbors for process 1
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
3   172.23.12.132           Tu8               11 00:01:18    1  5000  1  0
2   172.23.12.130           Tu8               12 2w4d       28  1434  0  8
0   172.23.12.131           Tu8               13 2w4d        9  1434  0  8
1   172.23.12.229           Vl1033            12 17w0d     265  1590  0  7255
                                            (sec)         (ms)       Cnt Num
3   172.23.12.132           Tu8               14 00:00:00    1  2000  1  0
2   172.23.12.130           Tu8               11 2w4d       28  1434  0  8
0   172.23.12.131           Tu8               12 2w4d        9  1434  0  8
1   172.23.12.229           Vl1033            11 17w0d     265  1590  0  7255
Of course, from 6509, 172.23.12.132 cannot be pinged.
One more thing, i noticed that the interface MTU of 4507 tunnel is incorrect although i configured the MTU.
4507#sh int tu8
Tunnel8 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 172.23.12.132/27
  MTU 17900 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.143.0.224 (Loopback108), destination 10.143.0.218
   Tunnel Subblocks:
      src-track:
         Tunnel8 source tracking subblock associated with Loopback108
          Set of tunnels with source Loopback108, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input never, output 00:00:03, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     42834 packets output, 8439260 bytes, 0 underruns
