%HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment
guizerabc
Getting the error: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: _mac
I have no idea why i',m getting that error only on 2 out of the 6 swithces on the lan. they all have the same script command for it.
regexp " *([0-9a-f]+\.[0-9a-f]+\.[0-9a-f]+) *STATIC *Gi([0-9/]+)" "$_line" _match _mac _port
My switches are C3750E, I don't believe they we're affected by that bug.
Dan Frey
Are you iterating over lines that do not match the regexp and if so do you have this if statement present in EEM?
if $_regexp_result eq 1
