HALP!!!! HALP!!!!
Currently have an Access Point wireless LAN Module (1252A)
Need to reset to factory defaults! We tried logging into the console via putty - this prompted a user name and password, and wouldnt you know it the guy that has this information passed away.
i would really appreciate any insight!
Kind Regards,
Sebastian
Rajeev Sharma
Hey Sebastian,
The default user name and password is Cisco. However if you want to reset it, here is the link:http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1250/installation/guide/1250HIG_TD-Book-Wrapper/125h_c3.html#wp1078182
HTH.
RS.
Rajeev Sharma
Hey Sebastian,
HTH.
RS.
I will try that! Thanks so much for helping, I will let you know how it goes!
Worked!!!
Now I just need to plug it in and try it out....
