Hardware Lifecycle
gdrandles
Level 2
Level 2
My client has already ordered the following:
Cisco 3825
Cisco 5520
Catalyst 4506
Cisco 4240
What are the typical hardware refresh for cisco gear? Do you just wait until a component fails or the product itself is end-of-life?
JORGE RODRIGUEZ
Level 11
Level 11
you brought up a very good question and hope you get many responces and opinions. I am very sure there is a lot of process that goes on on product life cycles . It seems to me the life cycle tends to be between 4 to 5 years depending on products, but I could be wrong. If you have SmartNet or a Cisco partner sales rep they usually advice in strategies for updating old platforms or when your products are due for updates and can work with you to migrate ro newer products.
Best thing is to address this question directly to Cisco Systems product representative where it can give you a very accurate answer.
End of life policy
http://www.cisco.com/en/US/products/products_end-of-life_policy.html
Usually Cisco list products on a regular basis informing products that have reaced end of life.
http://www.cisco.com/en/US/products/prod_end_of_life.html
Jorge Rodriguez
jwdoherty
Level 4
Level 4
My experience in the business world is that you won't usually do a full (forklift) refresh until the equipment has been fully depreciated and there's some "real" need for newer equipment. This usually doesn't happen in less then 3 years and usually happens, if it happens, before 10 years. (Ten years might seem a long time, but those who have to pay the bills like "if it ain't broke, don't replace it".) Things like the desktop move from 10 Mbps to 100 Mbps (or now gig?), or moving from hubs to switches, is where you might justify a full refresh.
Along the way to a full refresh, if ever, you often do replace or upgrade some equipment. This is not uncommon and seems to fall within a 4 to 5 year timespan, as noted by the prior poster.
Lastly, sometimes businesses expand and shrink. When they expand, you often obtain current equipment. Sometimes the newer expansion equipment might also require early upgrades to other existing production equipment. If you shrink, sometimes you can re-juggle equipment, replacing older with newer. These situations, though, aren't on a planned lifecycle but they can impact your existing equipment's lifecycle.
