have Problem with router
hackeemmana
Community Member
Hello everyone , i aour company we have configured the squid Proxy server now to end the project i need to cahnge the setting in the router so that people who brouse through the net they should browse through the Proxy Server ....
So please help by letting me know hoe to change the configuration in the router in order to attain the above results.
Martin Parry
Level 8
Level 8
You can apply the following acl to the inside interface.
ip access-list extended INSIDE_OUT
permit tcp host any eq www
permit tcp host any eq 443
deny tcp any any eq www
deny tcp any any eq 443
permit ip any any
Then you need to apply this to your inside interface in an inbound direction using the following command:
ip access-group INSIDE_OUT in
Hope this helps
Martin
