Having problem pinging from Switch to Router and between different VLANs
makhan007
Seb Rupik
Hi Asif,
Can you provide the following output:
On the router:
sh cdp neigh
sh int trunk
sh ip int br
sh int status | inc conn
Assuming the switch config is identical apart from the VLAN99 SVI's, from SW1:
sh int trunk
sh ip int br
cheers,
Seb.
cadet alain
you should configure f0/1 on sw1 as a trunk with switchport mode trunk
PC1 on sw3 has incorrect gateway it should be 192.168.4.254
Alain
makhan007
Hello Cadet and all thank you for your reply.
I fixed this problem last night after I posted this question.
I was considering fa0/1 from SW4 to router as not a trunk connection but as soon as I configured it as switcportmode trunk it worked.
But still thank you for your replies and help
