Help configuring ssh access to cisco 887vaW enbedded AP
Hello, i got some problem configuring my cisco 887VAW internet access point.
I want to be able to manage it thru ssh console with the service-module wlan-ap0 session mode. And i want to access thru http but it's not working too
I show you my config, please can you say me if there is something wrong in it, i'm a cisco noob
This is my config :
Current configuration : 3281 bytes
! Last configuration change at 21:43:11 UTC Fri May 18 2012 by jon
! NVRAM config last updated at 21:46:05 UTC Fri May 18 2012 by jon
version 15.1
hostname router-1
boot-start-marker
boot-end-marker
enable secret 5 xxx
enable password xxx
no aaa new-model
ip source-route
ip cef
ip dhcp excluded-address 192.168.2.254
ip dhcp excluded-address 192.168.2.0 192.168.2.100
no ip domain lookup
ip domain name jbtech.local
ip name-server 195.186.1.162
ip name-server 195.186.4.162
ip multicast-routing
no ipv6 cef
license udi pid C887VA-W-E-K9 snxxxxx
username jon privilege 15 password 0 xxxx
controller VDSL 0
operating mode vdsl2
modem co5
ip ssh version 2
class-map match-any Qos-Video
match protocol rtp video
match ip dscp af41
policy-map Qos-Ethernet0
class class-default
  fair-queue
policy-map Qos-Vlan1
class Qos-Video
  set dscp af41
class class-default
  set dscp default
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0
ip dhcp client broadcast-flag clear
ip address dhcp
ip pim sparse-mode
no ip mfib cef input
no ip mfib cef output
ip nat inside
no ip virtual-reassembly in
no ip route-cache
ip igmp query-max-response-time 8
ip igmp version 3
ip igmp query-interval 10
ip igmp querier-timeout 60
ip igmp proxy-service
load-interval 30
service-policy output Qos-Ethernet0
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
ip address 192.168.2.254 255.255.255.0
ip pim sparse-mode
ip nat inside
ip tcp adjust-mss 1452
ip igmp helper-address 1.1.1.1
ip igmp version 3
ip igmp explicit-tracking
load-interval 30
service-policy output Qos-Vlan1
interface Vlan20
description Vlan Wireless
ip address 192.168.20.1 255.255.255.0
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address 1.1.1.1
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.2.254
snmp-server community public RO
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
privilege level 15
password xxxxxxxx
login local
transport input ssh
transport output ssh
scheduler allocate 20000 1000
end
Thanks a lot.
Jon
when i connect to the router thru ssh is ok, but when i try to connect to session :
router-1#service-module wlan-ap 0 session
% telnet connections not permitted from this terminal
And when i do the same with the serial cable, it's ok.
