help for debug command
chmod700-r
Community Member
hi,
i want view how an access-list don't work properly but i want solve myself this problem.
I want use "debug IP packet detailed" for debug packet, but when i digit
Router#debug ip packet
i recive
IP packet debugging is on
how do i make to show debug?
thank in advantage.
regards
daniele
Hi Friend,
Not that I know off!! AFAIK only standard, extended access and expanded access list can be specified.
But you can use "term mon" to view any debugs on telnet session.
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Daniele,
If this is a telnet session then you need to enable "term mon" on enable prompt
Router#terminal monitor
Also I will recommend not to use debug ip packet as it may affect router CPU , I will suggest if you just want to troubleshoot an access list using debug command use "debug ip packet detail " and this will give you debug packets only for those specific ACLS and not all ip packets.
Ankur
Hi, thank you for your reply.
I've a named access-list, can i debug it?
i see that i can specify only access-list number
Hi Friend,
Ankur
