02-14-2013 03:44 PM - edited 03-07-2019 11:43 AM
HELP I NEED ADVISE ON CHOOSING ANOTHER ROUTER ??
I am working with a client who has a CISCO7201 which is at 100% CPU with 131,000 nat sessions.
7201: dies at 100% CPU, drops packets, end users see little or no traffic,
I replaced the 7201 with and ASR1002 with ESP5 and it is not much better.
ASR 1002: limping at 85% RP CPU, 62% SP CPU, drops packets, end users see 30% of actual plan speed.
The ASR is currently running at 83% RP CPU, 63% SP CPU with
WHAT ARE THE RECOMMEDATIONS AND ADVISE HERE, THE ASR1002 ISNT MUCH BETTER
FROM ASR1002
Total active translations: 110861 (423 static, 110438 dynamic; 110687
extended)
Outside interfaces:
GigabitEthernet0/0/0, Loopback6, Loopback127
Inside interfaces:
GigabitEthernet0/0/1.55
Hits: 5319971872 Misses: 122285308
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 123414071
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 pool cvc55 refcount 109542
pool cvc55: netmask 255.255.254.0
start 180.181.124.1 end 180.181.125.254
type generic, total addresses 510, allocated 150 (29%), misses 0
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
02-14-2013 04:06 PM
move the NAT to a firewall (pretty good sized one at that)
You are process switching all that NAT traffic,
02-14-2013 04:13 PM
Thank you. Which ASA would you recommend ? I was thinking ASA5525 or ASA5515 or one of the older ASA5550 ?
02-15-2013 08:15 AM
5515 minimum. 25 if you can swing it. Once you get the translations off the router, your performance should improve.
02-25-2013 10:47 AM
Gary,
When it comes to strict scaling, the ESP-5 is targeted at about 250K NAT translations, the ESP-10 is targeted at 1M NAT translations. I assume there are times when you end up above the level shown in the output above given your description of the level of CPU utilization. Here's a doc for reference:
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/data_sheet_c78-450070.html
The "Security" Section shows NAT translations on each ESP. Hope that helps.
-Nick
