help in operating csico 7604 with squid server with wccp protocol !
Dr.X
Level 2
Level 2
hi ,
i have the topology :
want to mention that im using port address translation on the router & not sure if it is making a conflict .
hereis the config below :
why the  cache is not working ??
i mean that i tried going to internet with source ips of the subnet 10.20.30 , but i seems went to internet without any precedence of cahce server .
i just want to troubleshoot and estimate of this problem from cahce or from router config
""i removed the unnecessary outputs""
Gateway7600#sh run
ip wccp 80 redirect-list CACHE80
ip wccp 90 redirect-list CACHE90
spanning-tree mode pvst
system flowcontrol bus auto
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface GigabitEthernet1/1
description lan
ip address 10.160.150.3 255.255.255.0
ip nat inside
ip wccp 80 redirect in
load-interval 30
interface GigabitEthernet1/3
ip address 192.168.250.1 255.255.255.252
ip wccp redirect exclude in
interface GigabitEthernet1/4
no ip address
shutdown
interface GigabitEthernet1/5
no ip address
shutdown
interface GigabitEthernet1/6
no ip address
shutdown
interface GigabitEthernet1/7
no ip address
shutdown
interface GigabitEthernet1/8
no ip address
shutdown
interface GigabitEthernet1/9
description  internet
ip address x.x.45.1 255.255.255.252
no ip redirects
ip nat outside
ip wccp 90 redirect in
load-interval 30
interface GigabitEthernet1/9.1
encapsulation dot1Q 2
interface Vlan1
no ip address
ip nat inside source list nat interface GigabitEthernet1/9 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 b.b.b.b
ip route xxxxx xxxxxxx
ip access-list extended CACHE80
permit tcp host 10.20.30.50 any eq www
permit tcp host z.z.z.z any eq www
ip access-list extended CACHE90
permit tcp any host 10.20.30.50
permit tcp any host z.z.z.107
ip access-list extended nat
permit ip 10.20.30.0 0.0.0.255 any
end
regards
jhiggins
per http://www.cisco.com/en/US/docs/ios-xml/ios/ipapp/configuration/12-4/iap-wccp.html
pdf page 27
ip nat inside
