Problem accessing Wireless Access Point from Remote Subnet
sstepun
Community Member
This is driving me nuts! I recently installed a couple of Cisco Aironet 3600 Series Wireless Access Points at a remote site. While I was at the site everything seemed OK, The clients were able to get connected to the access points, the guest network worked fine, I could SSH into the access points, and I could ping them. The problem is when I went back to my home site I tried to SSH into the access points through an ASA IPSec VPN Tunnel and it couldn’t find it. When I try to ping the access points they “time out”. I can ping and connect all other addresses (via RDP, HTTP, etc..) on the same subnet which should rule out an access list problem. A couple of notes to be aware of:
  • The WAP’s have the Autonomous IOS installed (Version 15.2(2)JB)
  • The WAP’s are connected to Dell PowerConnect 5724 (Not by choice.. We are a Cisco shop, these were already there and have plans this year to replace)
  • I can ping and SSH with Putty to the WAP’s from the local subnet
  • I cannot ping or SSH from a remote subnet to the WAP’s. I can access all other IP’s and Computers from a remote subnet.
Let me know if you need to look at any configs and I would be more than happy to supply
Thanks in advance!
Yes, by scrubbed I just mean with any personal details, password etc removed.
12 Replies 12
Gregory Snipes
Level 11
Level 11
Do all your ASAs have proper routes pointing the subnets down the correct tunnels/interfaces? This definitely seems to be a routing issue.
A routing issue was my first thought but I am able to access everything else on the same subnet
10.10.40.31 => 10.10.90.6  -  OK  (Laptop at Remote Site 1 to DC at Remote Site 2)
10.10.90.6 => 10.10.40.31  -  OK  (DC at Remote Site 2 to Laptop at Remote Site 1)
10.10.40.31 => 10.10.90.220  -  OK  (Laptop at Remote Site 1 to Switch at Remote Site 2)
10.10.90.220 => 10.10.40.31  -  OK  (Switch at Remote Site 2 to Laptop at Remote Site 1)
10.10.40.31 => 10.10.90.240  -  Time Out  (Laptop at Remote Site 1 to WAP at Remote Site 2)
10.10.90.240 => 10.10.40.31  -  Time Out  (WAP at Remote Site 2 to Laptop at Remote Site 1)
10.10.90.6 => 10.10.90.240  -  OK  (DC at Remote Site 2 to WAP at Remote Site 2)
10.10.90.240 => 10.10.90.6  -  OK  (WAP at Remote Site 2 to DC at Remote Site 2)
I am starting to wonder if this has something to do with the config on the WAP's. It's confusing...
So is there only one subnet at remote site 2? If so, I assume that when you are at remote site 2 you are in that subnet as well. Is this correct?
Additionally, are these autonomous of lightweight APs? How are they getting their IPs, static or DHCP? Would it be possible to post up a scrubbed config from one of them?
Forgive me for asking but when you say "scrubbed", does that mean removing anything revealing the company name, public IP's, etc..?
The APs were reloaded with the IOS that is not dependant on an access controller.
They have static IPs
There is only one subnet at the remote site with the exception of a VLAN created for the Guest network that is connected directly to the ASA on eth 0/2. When I am physically at the remote site (Remote Site 2), I have no problems connecting to it. When I am at my home site (Remote Site 1), I cannot connect.
BTW - I Clicked Answered somehow.... doh
Current configuration : 6161 bytes
! Last configuration change at 13:40:06 UTC Sat Mar 6 1993 by Cisco
version 15.2
no service pad
service password-encryption
hostname companyname-AP2
logging rate-limit console 9
enable secret 5 *****
aaa new-model
aaa group server radius rad_eap
server 10.10.90.6 auth-port 1812 acct-port 1813
aaa group server radius rad_acct
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip cef
ip domain name companyname.com
dot11 syslog
dot11 vlan-name companyname vlan 1
dot11 vlan-name companyname-Guest vlan 16
dot11 ssid companyname
   vlan 1
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa version 2
   mbssid guest-mode
dot11 ssid companyname-Guest
   vlan 16
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 *****
dot11 network-map
crypto pki trustpoint TP-self-signed-****
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-****
revocation-check none
rsakeypair TP-self-signed-****
crypto pki certificate chain TP-self-signed-****
certificate self-signed 01
        quit
username companyname privilege 15 password 7 *****
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 16 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
ssid companyname
antenna gain 0
stbc
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.16
encapsulation dot1Q 16
bridge-group 16
bridge-group 16 subscriber-loop-control
bridge-group 16 spanning-disabled
bridge-group 16 port-protected
bridge-group 16 block-unknown-source
no bridge-group 16 source-learning
no bridge-group 16 unicast-flooding
interface Dot11Radio1
no ip address
ssid companyname
antenna gain 0
dfs band 3 block
stbc
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
bridge-group 1
interface Dot11Radio1.16
bridge-group 16
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.16
no ip route-cache
bridge-group 16
interface BVI1
ip address 10.10.90.241 255.255.255.0
ip default-gateway 10.10.90.1
ip forward-protocol nd
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community **** RO
snmp-server community **** RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps cpu threshold
snmp-server enable traps aaa_server
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.10.90.6 auth-port 1812 acct-port 1813 key 7 ****
radius-server deadtime 2
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
end
All of the symptoms here point to a default gateway problem on the AP. However the gateway configuration looks good in the config you posted.
Is 10.10.90.1 the address of the firewall?
Yes, 10.10.90.1 is the firewall address. It's the inside interface of the Cisco ASA.
can you do this on the AP:
logging buffered debug
do debug ip icmp
do ping 8.8.8.8 repeat 2
do sh log
then post the output here
Alain
After running the first 3 commands, I do sh log and there is nothing in the output. I am running this within Putty via an SSH session. Does this matter?
sh logging
Syslog logging: enabled (0 messages dropped, 4 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 1097 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 2 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty1(2)
    Buffer logging:  level debugging, 1 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 538 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (1048576 bytes):
*Mar  6 16:57:31.458: %SYS-5-CONFIG_I: Configured from console by Cisco on vty0 (10.10.90.6)
no it doesn't matter here as you are looking at the buffer.
let's try this then:
do u all
access-list 199 permit icmp any any
do debug  ip pack detail 199
do sh log
Alain
I think the Mar 29 19:56 is what your looking for. Thanks for your help!
do sh log
    Console logging: level debugging, 1134 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 4 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 38 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 540 message lines logged
*Mar  6 17:17:49.409: %SYS-5-CONFIG_I: Configured from http by ergotron on 10.10.90.3
Mar 29 19:49:58.842: ICMP: dst (10.10.90.241) port unreachable sent to 10.10.90.6
Mar 29 19:52:41.632: ICMP: echo reply rcvd, src 10.10.90.1, dst 10.10.90.241, topology BASE, dscp 0 topoid 0
Mar 29 19:56:11.700: FIBipv4-packet-proc: route packet from (local) src 10.10.90.241 dst 8.8.8.8
Mar 29 19:56:11.700: FIBfwd-proc: Default:0.0.0.0/0 process level forwarding
Mar 29 19:56:11.700: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Mar 29 19:56:11.700: FIBfwd-proc: try path 0 (of 1) v4-sp first short ext 0(-1)
Mar 29 19:56:11.700: FIBfwd-proc: v4-sp valid
Mar 29 19:56:11.700: FIBfwd-proc:  no nh type 8  - deag
Mar 29 19:56:11.700: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if none nh none deag 1 chg_if 0 via fib 0 path type special prefix
Mar 29 19:56:11.700: FIBfwd-proc: Default:0.0.0.0/0 not enough info to forward via fib (none none)
Mar 29 19:56:11.700: FIBipv4-packet-proc: packet routing failed
Mar 29 19:56:11.700: IP: s=10.10.90.241 (local), d=8.8.8.8, len 100, unroutable
Mar 29 19:56:11.700:     ICMP type=8, code=0
Mar 29 19:56:13.699: FIBipv4-packet-proc: route packet from (local) src 10.10.90.241 dst 8.8.8.8
Mar 29 19:56:13.699: FIBfwd-proc: Default:0.0.0.0/0 process level forwarding
Mar 29 19:56:13.699: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Mar 29 19:56:13.699: FIBfwd-proc: try path 0 (of 1) v4-sp first short ext 0(-1)
Mar 29 19:56:13.699: FIBfwd-proc: v4-sp valid
Mar 29 19:56:13.699: FIBfwd-proc:  no nh type 8  - deag
Mar 29 19:56:13.699: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if none nh none deag 1 chg_if 0 via fib 0 path type special prefix
Mar 29 19:56:13.699: FIBfwd-proc: Default:0.0.0.0/0 not enough info to forward via fib (none none)
Mar 29 19:56:13.699: FIBipv4-packet-proc: packet routing failed
Mar 29 19:56:13.699: IP: s=10.10.90.241 (local), d=8.8.8.8, len 100, unroutable
Mar 29 19:56:13.699:     ICMP type=8, code=0
