Help me config vlan conection
xinh
Pleas help me
I need to configure the lab as follows
The vlan Id 10, 20, 30, 40 connect to each other
Internet connections as attached
Julio E. Moisa
If you want to enable communication between these network you could configure a routing protocol between these 3850 (if the have IP Base or IP Services license). Now if you want to provide Internet to each network independently you could create a default routing pointing to the each router from the switches and create NAT on the routers.
Are there many ways to configure the scenario, but could you provide more details, where the gateways are configured, the license of these switch (show version), do you need redundancy, etc.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Thank Julio Moisa Support
If you have lab this on cisco packet tracer please send to me
Thank Very Much
It think Cisco 3850 cannot be executed on packet tracer but I could share a config in order to be study by you.
Can you share config in order to me
I want know how it work
if you have file  packet tracer send to me
Thank you very much.
