Help me switch security
ccnamonsun
Community Member
In our campus we have a network of 192.168.2.0 with cisco switch 2950.
A segment called seg-1 is pulgged into switch port - 8(total 5 segments),
& our proxy server is plugged into port 3. now what i want is that i want ,
to restrict seg1 computers to access web taffic from that proxy server but
allow other traffic to flow unintruppet.
How & where can i implement ACL to achive such result ?
How to implement security of switch port to access or restrich different
kind of traffic
Give me solution.
7 Replies 7
marinos_g
Level 3
Level 3
In the following example web server has IP address 1.1.1.1.
Use your actual IP address.
interface FastEthernet0/8
description *** Connection to Segment 1 ***
no ip address
ip access-group 100 in
access-list 100 deny tcp any host 1.1.1.1 eq www
access-list 100 permit ip any any
This way all computers connected to switch port 0/8 will not be able to access web server 1.1.1.1 but they will be able to access anything else.
If you need specific computers connected to port 0/8 to be restricted, you'll need to change the access-list. You can use IP addresses in your access-list to perform per user or per subnet denial.
Please let me know more details to help you.
Marinos
Dear,
switch software :-Version 12.1(13)EA1
I am using 192.168.2.0 network in my whole campus.
1.As i explained u seg1(10 computers) connected to switch port 8 & proxy server is connected at port no 3.Now i want to restrict some seg1 's computer to access internet(web)only not other. how to achive that ?
2. I created an access list u shown me in answer but when i apply it on port 8 there is no such command as (ip access-list group 110) what i do. how can i enable that command on physical interface port 8.
Give me deatils i am novice.
plz. help me soon.
Please note that the command to apply the access-list on the interface is not ip access-list group but ip access-group
I can write to you the exact configuration you need, but I must know the following information:
1) What is the IP address of your web server?
2) What are the IP addresses of the PCs that will not access web service?
Assuming the following,
(192.168.2.10 -> web server)
(192.168.2.55 -> PC with no access to web server)
(192.168.2.58 -> PC with no access to web server)
(192.168.2.59 -> PC with no access to web server)
the configuration will be like this:
no ip address
access-list 100 deny tcp host 192.168.2.55 host 192.168.2.10 eq www
access-list 100 deny tcp host 192.168.2.58 host 192.168.2.10 eq www
access-list 100 deny tcp host 192.168.2.59 host 192.168.2.10 eq www
Please let me know the exact IP address you are using to write the exact configuration to use.
Marinos
Web server add :-192.168.2.1
Deny host are:-
192.168.2.4
192.168.2.5
192.168.2.8
192.168.2.10
I created that access list as u told me but,
How i apply it on port fa/8 clarify plz. since there is no command or option avilable as (ip access-group 100 in )
output (interface fa0/8):-
ITS2950(config-if)#ip ?
Interface IP configuration subcommands:
address Set the IP address of an interface
igmp IGMP interface commands
Now where how i appliy that. tell me soon
Regard
You are correct
a 2950 switch does not have the ip access-group command, but a 2950T does.
What you can do is create a VLAN interface and apply the access-list in the VLAN interface.
no ip address
switchport access vlan 2
interface vlan 2
access-list 100 deny tcp host 192.168.2.4 host 192.168.2.1 eq www
access-list 100 deny tcp host 192.168.2.5 host 192.168.2.1 eq www
access-list 100 deny tcp host 192.168.2.8 host 192.168.2.1 eq www
access-list 100 deny tcp host 192.168.2.10 host 192.168.2.1 eq www
Try this and tell me if it worked
Marinos
That's right but problem is that my all ports 1-24 are part of default vlan 1,
if i create another vlan then how i would be able to communicate with another (vlan1)
can i assign that access-list at vlan 1 itself. would it work ? since all ther ports r member of vlan 1
Yes, you can try this as well.
I'm not sure if it will work but it's worth a try.
Let me know how it will turn out.
