Help me with ACL, PAT, DHCP on router
hqwater.hjc
Hi. I'm configuring Access-lists, PAT, and DHCP to my router.
First please look at the attached image
(do not care about the VM.. they are bridged to individual nics and connected to SW1)
https://supportforums.cisco.com/servlet/JiveServlet/download/3579504-123917/topology.jpg
and the brief requirements for the topology:
1. hostsrv1 and hostsrv2 are seperated with vlan, done with dot1q trunking
2. use DHCP service on outside network. easy..
3. apply PAT on inside network
4. permit some ports on hostsrv1,2 and deny else.
trunking worked, DHCP worked, so I applied PAT, and something got wrong.
hostsrv can ping to GW(FE0/0), Client can ping to GW(FE0/0), but GW(FE0/0) cannot ping to Client eventhough client got ip from dhcp successfully.
access-list 101 was applied to FE0/0 but I disabled because of connection problem.
Is there anything that I have to do with FE0/1? I think all problems are based on dot1q trunking.....
my configuration is below :
__________
version 12.4
hostname GW
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 143.25.1.1 143.25.1.99
ip dhcp pool 143.25.1.0
   network 143.25.1.0 255.255.255.0
   default-router 143.25.1.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
interface FastEthernet0/0
ip address 143.25.1.1 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 172.16.1.1 255.255.255.240
ip nat inside
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.16.1.33 255.255.255.240
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 172.16.1.65 255.255.255.224
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 172.16.1.129 255.255.255.128
ip forward-protocol nd
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 101 permit tcp any host 172.16.1.2 eq 443
access-list 101 permit tcp any host 172.16.1.2 eq 3389
access-list 101 permit tcp any host 172.16.1.2 eq domain
access-list 101 permit tcp any host 172.16.1.34 eq www
access-list 101 permit tcp any host 172.16.1.34 eq 1723
control-plane
____________
I'll wait for any suggestions from you.
Thanks in advance!
0 Replies 0
