Help needed for 3750 switch
Hi all,
In my customer having 3750 switch and they have simply assign IP address for vlan and enable telnet in switch and other things are same as default switch.In this switch they have connected 8 cisco layer 2 switches(6 managed and 2 unmanged switch) and approximately 5 servers connected in this switch.In a particular interval,users accessing File server are connected to 3750 switch become hanged for few min.This happen for some particular interval.users accessing this server becomes entirely hanged for few min,then i have configured port monitor cmd and i have installed one wildshark tool to host connected directly to that switch.but i can't able to identify the issues.so kindly help how i trobleshoot this issues.
InayathUlla Sharieff
Hi Mohammed,
Ther are several things here to check:
1- What particular time the servers gets hunged?
2- How the switches are connected? Do they have single link or they have any etherchannel configured?
3- Whats the link utilization and cpu utlization during the issue? And also the status of Servers?
4- Were is the file server located?
Inayath
Hi Inayathulla,
Thanks for your response.
1.It will hunged around 7 pm IST.
2.They are connected with single link.
3.By using cisco configuration assistant tool,I have monitered cpu usage are nearer to 85 % and link utilization becomes up 79-90%.I have checked with server person, they told me its not an issues in server.
4.Locally and directly connected to 3750 switch.
kabeer
Hello
Can you post some readouts in txt file?
sh ver | in Base
sh spanning-tree root
sh vlan brief
sh log | b April
sh run
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
