Help possible configuration issue on 6506 port-channel
thekid1970
I've encountered some issues with a Cisco Cat 6506-E IOS connecting to a Cisco 6120 Fabric Interconnect. There is two portchannels consisting of 2 10GE ports in each of the PO connecting between each other.
The problem I'm having is that the interfaces one at a time are flapping through any given period. It goes down and within milliseconds it comes back up. Below is my config from the Cisco 6506 and the both 6120's.
From the Cisco 6506, the port channel and interface configurations are as below:
interface Port-channel113
description [-[ Port Channel to MgmtAMP 6120 ]-]
switchport
switchport trunk allowed vlan 1,101-112,216,221,240,315,406,407,411,416,417
switchport trunk allowed vlan add 440-447
switchport mode trunk
mtu 9216
lacp fast-switchover
spanning-tree portfast edge trunk
interface Port-channel114
switchport
mtu 9216
interface TenGigabitEthernet3/3
description [-[ Connection to u6120-d7-a port 1/18 ]-]
switchport
mtu 9216
logging event link-status
channel-protocol lacp
channel-group 113 mode active
lacp port-priority 10
lacp rate fast
interface TenGigabitEthernet3/4
description [-[ Connection to u6120-d7-b port 1/18 ]-]
switchport
mtu 9216
channel-group 114 mode active
lacp rate fast
interface TenGigabitEthernet4/1
description [-[  Connection to u6120-d7-a port 1/17  ]-]
switchport
mtu 9216
lacp rate fast
interface TenGigabitEthernet4/2
description [-[  Connection to u6120-d7-b port 1/17  ]-]
switchport
mtu 9216
lacp rate fast
From the Cisco 6120-A, the port channel and interfaces configurations are as below:
interface port-channel113
  switchport trunk allowed vlan 1,101-112,216,240,315-316,321,328
  switchport trunk allowed vlan add 340-341,406-407,411,416-417,440-447
  pinning border
  speed 10000
interface Ethernet1/17
  switchport trunk allowed vlan 1,101-106,110-112
  pinning border
  no shutdown
interface Ethernet1/18
  pinning border
  no shutdown
From the Cisco 6120-B, the port channel and interfaces configurations are as below:
interface port-channel114
  pinning border
  speed 10000
  pinning border
  no shutdown
  pinning border
  no shutdown
On the 6506 side, when I issue the "debug etherchannel", I see these errors popping out:
Jun 20 14:17:53.881: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet4/1, changed state to up
Jun 20 14:17:53.921: %LINEPROTO-SP-5-UPDOWN: Line protocol on Interface TenGigabitEthernet3/4, changed state to up
Jun 20 15:21:32.025: FEC: pagp_switch_init_and_copy_fecblock: port Te3/3
Jun 20 15:21:32.025: FEC: pagp_switch_init_and_copy_fecblock: port Te4/2
If anybody can help would appreciate it.
John Roberts
andrew.prince
Level 10
Level 10
Chaitra Shree
Hi John,
Are there any logs like "%EC-SP-5-CANNOT_BUNDLE_LACP" under show log output ?
Have you observed any input or output drops on the port-channel or its members ?
Could you provide "show log" and "show etherchannel summary" output from the switch ?
