Help!!! Redundancy on Switch Layer 3 using VTP + STP + HSRP
JackyHo
I'm using Packet Tracer version 7.1.1 for my testing purpose before performing to the real device.
Network topology:
- Distribution SW1 (DLS1) and Distribution SW2 (DLS2) => same model Cisco 3650
- Access Switch (ALS1): model Cisco 2960
Experiencing issues:
1. Some link not blinking
Why the few link is not blinking? Any wrong config?Why the few link is not blinking? Any wrong config?
2. ICMP with high latency
ICMP high latencyICMP high latency
3. HSRP is working not properly.
I'm stressing with it, I think something wrong configures but I still not figure-out.
I need someone to help me a favor to figure-out the root cause. Thanks.
See my Switch configure in the attached files.
Hello
What is your issue here? I am not able to open those files at present so cannot see the config?
Can you tell me if that link you are showing is a port-channel or a normal trunk/access connection?
Do you have separate hrsp groups for your vlans or just using the one group?
If you can post the packet-tracer file
Kind Regards
Paul
Hi Paul,
See the config as per switch below, help me a favor to take a look there is anything wrong in config. Thanks
DLS1
Building configuration...
Current configuration : 4446 bytes
version 16.3.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname DLS1
no ip cef
ip routing
no ipv6 cef
no ip domain-lookup
spanning-tree mode rapid-pvst
spanning-tree vlan 18-23 priority 24576
interface Port-channel1
switchport mode trunk
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
channel-group 1 mode on
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan18
mac-address 00e0.8f7c.9101
ip address 10.18.200.2 255.255.255.0
standby 1 ip 10.18.200.1
standby 1 priority 101
standby 1 preempt
interface Vlan19
mac-address 00e0.8f7c.9102
ip address 10.19.10.2 255.255.255.0
standby 1 ip 10.19.10.1
standby 1 preempt
interface Vlan20
mac-address 00e0.8f7c.9103
ip address 10.20.10.2 255.255.255.0
standby 1 ip 10.20.10.1
standby 1 preempt
interface Vlan21
mac-address 00e0.8f7c.9104
ip address 10.21.10.2 255.255.255.0
standby 1 ip 10.21.10.1
standby 1 preempt
interface Vlan22
mac-address 00e0.8f7c.9105
ip address 10.22.10.2 255.255.255.0
standby 1 ip 10.22.10.1
standby 1 preempt
interface Vlan23
mac-address 00e0.8f7c.9106
ip address 10.23.10.2 255.255.255.0
standby 1 ip 10.23.10.1
standby 1 preempt
interface Vlan40
mac-address 00e0.8f7c.9107
ip address 10.40.40.2 255.255.255.0
standby 1 ip 10.40.40.1
standby 1 preempt
interface Vlan50
mac-address 00e0.8f7c.9108
ip address 10.50.50.2 255.255.255.0
standby 1 ip 10.50.50.1
standby 1 preempt
interface Vlan70
mac-address 00e0.8f7c.9109
ip address 10.70.70.2 255.255.255.0
standby 1 ip 10.70.70.1
standby 1 preempt
interface Vlan100
mac-address 00e0.8f7c.910a
ip address 10.100.10.2 255.255.255.0
standby 1 ip 10.100.10.1
standby 1 preempt
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
DLS2
Current configuration : 4405 bytes
version 16.3.2
hostname DLS2
no ip cef
ip routing
no ipv6 cef
no ip domain-lookup
spanning-tree vlan 40,50,70,100 priority 24576
interface Vlan1
no ip address
shutdown
interface Vlan18
mac-address 0001.c96d.3201
ip address 10.18.200.3 255.255.255.0
standby 1 preempt
interface Vlan19
mac-address 0001.c96d.3202
ip address 10.19.10.3 255.255.255.0
standby 1 preempt
interface Vlan20
mac-address 0001.c96d.3203
ip address 10.20.10.3 255.255.255.0
standby 1 preempt
interface Vlan21
mac-address 0001.c96d.3204
ip address 10.21.10.3 255.255.255.0
standby 1 preempt
interface Vlan22
mac-address 0001.c96d.3205
ip address 10.22.10.3 255.255.255.0
standby 1 preempt
interface Vlan23
mac-address 0001.c96d.3206
ip address 10.23.10.3 255.255.255.0
standby 1 preempt
interface Vlan40
mac-address 0001.c96d.3207
ip address 10.40.40.3 255.255.255.0
standby 1 preempt
interface Vlan50
mac-address 0001.c96d.3208
ip address 10.50.50.3 255.255.255.0
standby 1 preempt
interface Vlan70
mac-address 0001.c96d.3209
ip address 10.70.70.3 255.255.255.0
standby 1 preempt
interface Vlan100
mac-address 0001.c96d.320a
ip address 10.100.10.3 255.255.255.0
standby 1 preempt
ip classless
line con 0
line aux 0
line vty 0 4
login
end
ALS1
hostname ALS1
no ip domain-lookup
interface FastEthernet0/1
switchport access vlan 100
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 21
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan1000
ip address 10.10.10.8 255.255.255.0
ip default-gateway 10.10.10.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
pieterh
to clarify the setup you could
- enable port-names in the graphic
- set port-descriptions in the config
my guess is DLS1 and DLS2 are connected using Po1 (Gi1/0/23 + Gi1/0/24)
also ALS1 is connected using Gi0/1 and Gi0/2
but it is not clear if the links in the graphic are those ports.
on the ALS1 you possibly connect Gi1/0/23 + Gi1/0/24 to DLS1/2 and you configured a port-channel for this
but on the DLS1/2 the ports ar NOT port-channel
You cannot span a port-channel across two switches that are not stacked or VSS
please remove the "channel-group 1 mode on" in the ALS1 config
