Help regarding cisco 2801
M Talha
Hi everyone,
I have little problem regarding my cisco 2801 configurations. The thing is i have Cisco 2801 with two fast Ethernet ports, i have programmed one port for WAN link and the other one for my local network. Everything is working fine from DHCP to WAN link establishment but i have not been able to access web although when i ping Google or Yahoo ip addresses it is working 100% fine.
I will greatly thankful if someone can help me in this regard.
here is my configuration
Router#sh run
Building configuration...
Current configuration : 1359 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$48q6$RYDWFi8fJ6WzB5Wfp8y7l0
enable password cisco
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.1.4 10.1.1.150
ip dhcp excluded-address 10.1.1.1 10.1.1.2
ip dhcp excluded-address 10.1.1.1 10.1.1.3
ip dhcp pool 0
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   dns-server 58.27.149.60 58.27.196.70 202.163.96.3
   lease 15
interface FastEthernet0/0
description Wan Link
ip address 58.27.246.10 255.255.255.252
ip nat outside
ip nat enable
duplex auto
speed auto
interface FastEthernet0/1
description CONNECTED_TO_LAN
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip nat enable
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 58.27.246.9
no ip http server
ip nat pool SCL 58.27.246.10 58.27.246.10 prefix-length 30
ip nat inside source list 100 pool SCL overload
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
paolo bevilacqua
use ip nat.. interface, not pool.
no ip nat pool SCL 58.27.246.10 58.27.246.10 prefix-length 30
no ip nat inside source list 100 pool SCL overload
ip nat inside source list 100 interface fa 0/0 overload
Jawad
Jawad
