help,which 6509 Process is executed directly to cpu
laowanglaoli
help,which 6509 Process is executed directly to cpu?
thanks
ebreniz
Level 6
Level 6
The CPU utilization is made up of 2 factors:
1 - how often a process is scheduled
2 - how long the process holds the cpu
the high CPU utilization when the system is idle is not an issue, it is by design so you have to think what application has to use and which to avoid.
