Help with a PING issue
jfrancois
Community Member
Ladies and Gents;
I need your help with an easy issue but I can't seem to figure it out. To keep things simple, I am going to just keep it to three devices: I have a 2630 router connects to a Catalyst 3550 Multilayer Switch and I have a laptop connects to it. That's it! Here are the configurations:
Router
interface Ethernet0/0
ip address 172.20.10.1 255.255.255.0
no ip directed-broadcast
interface Serial0/0
ip address 192.168.65.2 255.255.255.252
service-module t1 clock source internal
router ospf 10
area 2 stub
network 172.20.10.0 0.0.0.255 area 2
network 192.168.65.0 0.0.0.3 area 2
ip classless
3550 switch
interface FastEthernet0/1
switchport mode access
no ip address
spanning-tree portfast
end
Malvern#sh run int fa0/2
Building configuration...
Current configuration : 131 bytes
interface FastEthernet0/2
switchport mode dynamic desirable
no ip address
duplex full
speed 100
end
interface Vlan1
ip address 172.20.10.2 255.255.255.0
no ip route-cache cef
ip default-gateway 172.20.10.1
ip classless
ip http server
-The router connects to the Port 1 on the 3350 switch
-The laptop connects to the laptop on Port 2
- IP address of the laptop is 172.20.10.1 / 255.255.255.0 / DG 172.20.10.1
Here is my question:
From the laptop, I can ping the switch and both interfaces in the router. I also can ping from the router to the switch BUT I CAN'T ping from the edge switch to the laptop. In other words, the ping works one way but doesn't the other way while I don't have any ACL in the router.
Thank you in advance for any suggestion;
-JMF
6 Replies 6
Richard Burts
JMF
Are you on purpose using the same IP address on the PC as is on the router interface? I believe that this address duplication is your problem. Change the PC address to some other host address in that subnet and see if things do not work better.
Rick
Rick
Sorry. That was a typo - the IP for the laptop is 172.20.10.3
JMF
If I am understanding your situation correctly then the symptoms are that the laptop can ping other devices but the other devices can not ping the laptop. The common cause of this is a firewall on the laptop which will not allow incoming ping. Please disable the firewall on the laptop and see if the behavior changes.
Rick
Rick
Sorry Rick. This laptop is in my lab where I experienced the issue. If I connect it to my live network, I can ping it fine.
-JMF
Guys;
"Cisco Security agent" was the guilty party. Rick, you were right. Thank you very. You guys are the Bum!!!!
-JMF
JMF
I am glad that you got it worked out. Cisco Security agent is a bit of a surprise but does fit the general behavior.
Rick
Rick
