Help with an ACL
Gregory Forster
I have multiple subnets blocked out from 10.2.0.0/16 each subnet is a /24. I would like to block the 10.2.19.0/24 subnet from accessing all other subnets. How would I go about doing this, would I need to create an ACL with a line for each subnet, or could I just create an ACL that blocks all subnets?
You need to use an extended acl eg -
access-list 101 deny 10.2.19.0 0.0.0.255 10.2.0.0 0.0.255.255
access-list 101 permit 10.2.19.0 0.0.0.255 any
then apply to the interface as per your example.
Jon
9 Replies 9
Jon Marshall
Just deny 10.2.19.0/24 to 10.2.0.0/16 and then allow 10.2.19.0/24 to any other IP if they need to talk to other subnets or the internet for example.
Then apply the acl inbound on the L3 interface for the 10.2.19.0/24 subnet.
Jon
So my config would look like this?
access-list 19 deny 10.2.19.0/24 0.0.0.255 10.2.0.0 0.0.0.255
access-list 19 permit any
interface vlan 19
access-group 19 in
Jon
Gregory Forster
Jon,
I was just doing that as you replied. Thank you so much for verifying this for me.
No problem, glad to help.
Jon
Jon,
Ok I tried that and I am still able to ping other subnets. Config is shown below
access-list 101 deny ip 10.2.19.0 0.0.0.255 10.2.0.0 0.0.255.255
access-list 101 permit ip 10.2.19.0 0.0.0.255 any
interface Vlan19
description Video-VLAN19
ip address 10.2.19.x 255.255.255.0
ip access-group 19 in
You are referencing the wrong acl ie. change this -
to
ip access-group 101
my fault, should have been clearer in my earlier response.
Jon
Jon,
I am so dumb. Thanks for pick that out for me.
Not dumb, easy mistake to make and I wasn't very clear in my previous answer.
Jon
