Help with Catalyst 3512 XL CNA
samjproctor1
Im not going to lie, I'm pretty much a beginner when it comes to switches.  I have recently purchased a second hand 3512 XL which I have managed to connect to via PuTTY and the console cable. I have familiarised myself with access privileges and resetting passwords and locating the IP address, etc.
I am trying to connect the switch to Cisco Network Assistant however I am unable to connect to the switch over a cat5 on the first port (nothing else is on the network, just a server directly to the switch).  I have tried pinging the switch from my server, and similarly I have tried pinging the server from the switch and each time there is 100% fail rate.  Can anyone help me trace this problem?
samp17
Is it interface vlan 1 you have set the IP address on the switch? If so, make sure the port the server is connected to is on vlan 1.
If that is the case, make sure that the switch and the server is on the same range if IP addresses (subnet).
Check that to begin with, tell me if it doesn't work.
edondurguti
Level 4
Level 4
if you just want to have your pc talk to the switch and nothing else ( not connection the swith to the network ) here's what you would have to do:
set your pc an ip address: 192.168.1.1
go to your switch with console cable
enable
conf t
ip default-gateway 192.168.1.1
interface vlan 1
ip address 192.168.1.2 255.255.255.0
end
connect your pc to any port of the switch
from switch ping 192.168.1.1 - should work
if  you want it in your network then set ip default-gateway to your gateway form your pc (if you use windows go start - run type cmd) and do ipconfig ... find your gateway and set it to switch.
if your pcs ip is 192.168.1.x then set vlan1 ip 192.168.1.55 for example
interface vlan1
ip address 192.168.1.55 255.255.255.0
hth
Leo Laohoo
Duplicate post
CNA and 3500XL?  You'll need a pretty old version of the CNA to get this running.  Look at the Release Notes of your CNA version which will tell you what appliance is supported.
