Help with ISR4331
demiller
I have an isr 4331 that was purchased with Cisco ONE licensing. it was pulled out of service and configuration wiped. Took it to replace another isr in the field and now the sh license command shows deactivated for everything. out put below:
sh license
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
How do i activate the license we purchased with the router?
2 Accepted Solutions
ISR4331#license install
should let you install any of the licenses displayed in your output. Make sure smart licensing is disabled:
ISR4331#conf t
ISR4331(config)#no license smart enable
I rehosted the license and that did it. thanks
ISR4331#conf t
