Help with OSPF configuration (Multi-layer switch)
haydenirvin
I seem to be configuring OSPF wrong. Need some help. Can one of you assist me?
Here are my configs
Router 1 Config
en
config t
int g0/0
ip add 192.168.0.254 255.255.255.0
no shut
int g0/1
ip add 172.16.0.2 255.255.255.252
no shut
int g0/2
ip add 172.16.0.6 255.255.255.252
no shut
router ospf 1
network 192.168.0.0 0.0.0.255 area 0
network 172.16.0.0 0.0.0.3 area 0
network 172.16.0.4 0.0.0.3 area 0
Multilayer switch 1 (Left side)
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
ip add 10.0.0.126 255.255.255.128
no shut
ip helper-address 192.168.0.1
int vlan 10
ip add 10.0.0.190 255.255.255.192
no shut
int vlan 15
ip add 10.0.0.254 255.255.255.192
no shut
int g1/0/24
switchport mode acc
switchport mode trunk
no shut
exit
ip routing
router ospf 1
network 10.0.0.0 0.0.0.127 area 0
network 10.0.0.128 0.0.0.63 area 0
network 10.0.0.192 0.0.0.63 area 0
Multilayer switch 2 (right side)
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
ip add 10.0.1.126 255.255.255.128
no shut
int vlan 10
ip add 10.0.1.190 255.255.255.192
no shut
int vlan 15
ip add 10.0.1.254 255.255.255.192
no shut
int g1/0/24
switchport mode acc
exit
ip routing
router ospf 1
network 10.0.1.0 0.0.0.127 area 0
network 10.0.1.128 0.0.0.63 area 0
network 10.0.1.192 0.0.0.63 area 0
2 Accepted Solutions
kapilsoni21
Remove interface configuration of port gi1/0/24 from both the multilayer switch, and configure the IP addresses from the same subnet which is used by you to connect to router 1, Hope below-mentioned configuration will help you On right side Multilayer switch conf t int g1/0/24 ip add 172.16.0.1 255.255.255.252 no sh exit On Left side Multilayer switch conf t int g1/0/24 ip add 172.16.0.5 255.255.255.252 no sh exit
Jaderson Pessoa
@haydenirvin Hello,
Do below changes
Router 1 Config
en
config t
int g0/0
no shut
int g0/1
no shut
int g0/2
no shut
router ospf 1
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
no shut
int vlan 10
no shut
int vlan 15
no shut
int g1/0/24
no switchport mode acc
no switchport mode trunk
ip address 192.168.0.253 255.255.255.0
ip ospf 1 area 0
exit
ip routing
router ospf 1
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
no shut
int vlan 10
no shut
int vlan 15
no shut
int g1/0/24
ip address 172.16.0.5 255.255.255.252
ip ospf 1 area 0
exit
ip routing
router ospf 1
Jaderson Pessoa
*** Rate All Helpful Responses ***
5 Replies 5
kapilsoni21
Thank you
Jaderson Pessoa
@haydenirvin Hello,
Do below changes
Router 1 Config
en
config t
int g0/0
no shut
int g0/1
no shut
int g0/2
no shut
router ospf 1
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
no shut
int vlan 10
no shut
int vlan 15
no shut
int g1/0/24
ip ospf 1 area 0
exit
ip routing
router ospf 1
en
config t
vlan 5
vlan 10
vlan 15
int vlan 5
no shut
int vlan 10
no shut
int vlan 15
no shut
int g1/0/24
ip ospf 1 area 0
exit
ip routing
router ospf 1
Jaderson Pessoa
haydenirvin
I needed to do the no switchport command. Thank you
glad to help :)
Jaderson Pessoa
