Help with serial interface
aaron.cowell.au
Community Member
I cannot get two frame relay serial interfaces to communicate. Can any body help. Why wont
Serial1/0 is up, line protocol is down (looped) ping each other?
Router 1
Current configuration : 1465 bytes
upgrade fpd auto
version 12.4
hostname router2
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 10.0.0.1 255.255.255.0
encapsulation frame-relay
serial restart-delay 0
clock rate 112000
frame-relay interface-dlci 150
frame-relay lmi-type cisco
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Router2
Current configuration : 1467 bytes
upgrade fpd auto
version 12.4
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
memory-size iomem 0
archive
log config
  hidekeys
no ip address
shutdown
duplex half
interface Serial1/0
ip address 10.0.0.254 255.255.255.0
clock rate 112000
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
no ip http server
control-plane
mgcp fax t38 ecm
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
  Hardware is M8T-X.21
  Internet address is 10.0.0.1/24
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Encapsulation FRAME-RELAY, crc 16, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  LMI enq sent  135, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down
  LMI enq recvd 134, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 1023  LMI type is CISCO  frame relay DTE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
  Last input 00:00:07, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:26:19
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     136 packets input, 1768 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     136 packets output, 1768 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     1 carrier transitions     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
John Blakley
It looks like your ISP may have the circuit looped somewhere down the line. Have you contacted them or is this a lab? If this is back to back, try disabling lmi with "no keepalive" on the interfaces.
HTH, John *** Please rate all useful posts ***
Hello John,
This looks like a lab (S1/0 reminds me strongly of Dynamips).
In any case, on Frame Relay, disabling the keepalives is not a good idea, as it deactivates the LMI protocol completely. In a back-to-back scenario, it will help, but also it is teaching people to configure the Frame Relay connection the wrong way. If they did that in a real Frame Relay network, they would most certainly prevent themselves from ever getting it to work.
Ideally, one of the devices here should be configured as Frame Relay DCE device and specifically declare the DLCI number to use. In Aaaron-James's configuration, the DLCI number has already been specified - it is 150. Now, one (and only one) of these routers should be configured as FR DCE device - that allows it to respond to LMI messages sent by the other (i.e. FR DTE) device. For example, on Router 2, enter these commands:
configure terminal
frame-relay switching
interface Serial1/0
  frame-relay intf-type dce
end
That should do the trick, hopefully. Just to remove any doubt: FR DCE/DTE designations are related to the responsiblity of a device to originate/respond to LMI messages. They are not in any way related to the cabling and physical DCE/DTE.
Best regards,
Peter
John Blakley
Peter,
Frame relay isn't one of my string points, but Cisco has a document on back to back FR connections and states that disabling LMI is a requirement to get it to work. Is this not the case? If not, I'll have to lab this up to see if I can get it to work.
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a0080094a3b.shtml
John
Peter Paluch
Hi John,
In Frame Relay, devices depend on Local Management      Interface (LMI) signalling - a helper protocol used on a per-link basis      that allows the attached devices to verify their liveliness and to      discover the individual DLCIs and their status.
The LMI      is an asymmetrical protocol in that the devices are designated  either     as DTE or DCE devices. The Frame Relay DTE device is the  endpoint of a     virtual circuit, usually a router. DTE devices emit  LMI Status  Enquiry    messages to find out about DLCI numbers and their  status, and  expect  to  receive a LMI Status Reply back. This Status  Reply is  generated by  the  DCE device which is usually a Frame Relay  switch.   Therefore, DTE   devices send Status Enquiries, DCE devices  send Status   Replies. It does   not work in reverse: a DTE device  cannot send Status   Replies, and a   DCE device cannot send Status  Enquiries.
If   a DTE device  does not receive replies to  its Status  Enquiry  messages,  it assumes  that the opposite device  does not work or  does  not speak  Frame Relay,  and puts its interface  into up/down state.   Similarly, if a  DCE device  does not receive  periodic Status Enquiries,   it assumes that  the  opposite device does  not work or does not speak   Frame Relay, and  also  declares a "line  protocol down" condition.
By default, Cisco devices work as Frame Relay DTE devices on their interface, as can be easily seen using a show interfaces command:
R1_A#show int s1/0
Serial1/0 is up, line protocol is up
  Hardware is M4T
  Internet address is 1.1.1.1/24
  CRC checking enabled
  LMI enq sent  1, LMI stat recvd 0, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
So     if two routers are connected back-to-back, each of  them behaves as a     FR DTE device, sends Status Enquiries but never  receives a Status    Reply  back, and thus the connection does not come up. A     quick-and-dirty fix  is to deactivate the LMI altogether on both devices     using the no keepalive command and that is what the document suggests.
However,     if you did that in a real network, you would  prevent an otherwise     correctly configured FR connection from coming up:  the DTE would not     send Status Enquiries to the DCE (the FR switch), or  the DCE would  not    respond to DTE's enquiries. In any case, the  connection would  not be    working unless you deactivated the LMI on both  ends. But why  would  you   want to deactivate the LMI on both ends if they  are  configured  and   connected properly and when LMI provides an important      signalling/management aspect to the Frame Relay? It is more correct,      even in a back-to-back scenario, to configure one of the devices to  work     in a DCE mode and to allow LMI to work as intended - and that  is the     point of my suggested configuration correction.
So this is the long story behind why I dislike the no keepalive fix - it works on a back-to-back connection but it can wreak havoc in      real FR network if one is not very well aware of what this really   does.
Best regards,
Peter
