Help with sho int x/xx switchport command
jonesm111
I'm trying to find out if all vlans are allowed or are they pruned??
not easy to tell..
ss-us-sjc-640-102#sho int gi 0/22 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
they are allowed but not necessarily being forwarded, the last part of this output will tell you if they are being forwarded.
"Vlans in spanning tree forwarding state and not pruned"
If you want to clear some of the vlans on that trunk port, you will need to clear it from that trunk:
Defining the Allowed VLANs on a Trunk
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_sec/configuration/guide/swvlan.html#wp1150302
5 Replies 5
Roberto Salazar
Level 8
Level 8
From the output above the port is shutdown mode >> Operational Mode: down. do a show run int g 0/22, do you see "shutdown" under that interface's running config? To see what vlans are being forwarded and not pruned do a "show int trunk" but if the port is in shutdown state you will not see that interface in the output. To see what vlans are cleared from the trunk - show run int g x/x.
Yudong Wu
Level 7
Level 7
Port 0/22 is in access mode.
Administrative Mode: static access <<<<<
It is in default vlan 1.
Packet in vlan 1 will be forwarded.
Access Mode VLAN: 1 (default) <<<<<
Roberto Salazar
Level 8
Level 8
Kevin is right, this port is in access mode which means even if it is up it will not be trunking, thefore the onle vlan allowed will be, in your case, vlan 1.
Sorry Guys, that was the wrong int..
Here is the right one.. looks to me like it's part of po2 and all vlans are trunked?
ss-us-sjc-640-101#sho int gi 0/23 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: trunk (member of bundle Po2)
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Voice VLAN: none
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
ss-us-sjc-640-101#sho int trunk
Port Mode Encapsulation Status Native vlan
Po1 desirable 802.1q trunking 1
Po2 desirable 802.1q trunking 1
Port Vlans allowed on trunk
Po1 1-4094
Po2 1-4094
