6509 high CPU utilization
luisamato
Community Member
Hello everybody, I have a situation, and y wanted to investigate if this is normal or not.
On a 6509 router ( 720 supervisor ) I start a "ping X.X.X.X size 5000 repeat 100000" from the supervisor to any host, and the CPU is incremented to 100%.
Can anyone affirm that this is usual ? I read this article and I think it is! (http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml)
Here is the output of a show proccess with the ping running.
Without the ping it is at 5%.
#show processes cpu
CPU utilization for five seconds: 100%; one minute: 100%; five minutes: 99%
PID 5Sec 1Min 5Min Process
1 0.0% 0.1% 0.3% kernel
3 0.0% 0.0% 0.0% devc-pty
4 0.0% 0.0% 0.0% devc-mistral.proc
5 0.0% 0.0% 0.0% pipe
4102 0.0% 0.0% 0.0% dumper.proc
4103 0.0% 0.0% 0.0% pcmcia_driver.proc
4104 0.0% 0.0% 0.0% bflash_driver.proc
12297 0.0% 0.0% 0.0% mqueue
12298 0.0% 0.0% 0.0% flashfs_hes.proc
12299 0.0% 0.0% 0.0% dfs_bootdisk.proc
12300 0.0% 0.0% 0.0% ldcache.proc
12301 0.0% 0.0% 0.0% watchdog.proc
12302 0.0% 0.0% 0.0% syslogd.proc
12303 0.0% 0.0% 0.0% name_svr.proc
12304 0.0% 0.0% 0.0% wdsysmon.proc
12305 0.0% 0.0% 0.0% sysmgr.proc
16386 0.0% 0.0% 0.0% chkptd.proc
16402 0.0% 0.0% 0.0% sysmgr.proc
16403 0.0% 0.0% 0.0% syslog_dev.proc
16404 0.0% 0.0% 0.0% itrace_exec.proc
16405 0.0% 0.0% 0.0% packet.proc
16406 0.0% 0.0% 0.0% installer.proc
16407 88.4% 88.3% 86.8% ios-base
16408 0.0% 0.0% 0.0% fh_fd_rf.proc
16409 0.0% 0.0% 0.0% fh_fd_oir.proc
16410 0.0% 0.0% 0.0% fh_fd_env.proc
16411 0.0% 0.0% 0.0% fh_fd_cli.proc
16412 0.0% 0.0% 0.0% fh_metric_dir.proc
16413 0.0% 0.0% 0.0% fh_fd_test.proc
16414 0.0% 0.0% 0.0% fh_fd_snmp.proc
16415 0.0% 0.0% 0.0% fh_fd_none.proc
16416 0.0% 0.0% 0.0% fh_fd_intf.proc
16417 0.0% 0.0% 0.0% fh_fd_gold.proc
16418 0.0% 0.0% 0.0% fh_fd_timer.proc
16419 0.0% 0.0% 0.0% fh_fd_ioswd.proc
16420 0.0% 0.0% 0.0% fh_fd_counter.proc
16421 0.0% 0.0% 0.0% fh_server.proc
16422 0.0% 0.0% 0.0% fh_policy_dir.proc
16423 0.0% 0.0% 0.0% call_home.proc
16424 0.0% 0.0% 0.0% ipfs_daemon.proc
16425 0.0% 0.0% 0.0% fh_fd_config.proc
16426 2.2% 2.0% 2.0% raw_ip.proc
16427 0.0% 0.0% 0.0% inetd.proc
16428 8.4% 8.7% 8.6% tcp.proc
16429 0.0% 0.0% 0.0% udp.proc
16430 0.0% 0.0% 0.0% iprouting.iosproc
16431 0.5% 0.4% 0.4% cdp2.iosproc
Edison Ortiz
The packet is too large and needs to be fragmented which requires CPU cycles.
What you are seeing is normal, avoid packet fragmentation at all cost.
HTH,
__
Edison.
7 Replies 7
Edison Ortiz
HTH,
__
Edison.
Thank you for your soon answer.
Now please look at this command. Is this CPU consumption normal, why. Now we haven't got any fragmentation.
This is the command:
#ping 172.17.8.66 repeat 10000
This is the status of the CPU wile the ping runs:
#sh processes cpu history
99988877765432
3208529504788592223334543222233333334444566766554455673222
100
90 *****
80 ********
70 *********
60 ***********
50 ************
40 *************
30 **************
20 **************
10 *************** * ******** ****
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
* = maximum CPU% # = average CPU%
G100603RT000#sh processes cpu
CPU utilization for five seconds: 99%; one minute: 37%; five minutes: 15%
1 0.0% 0.1% 0.1% kernel
16407 65.0% 23.9% 9.8% ios-base
16426 4.5% 1.7% 0.6% raw_ip.proc
16428 28.9% 10.1% 3.5% tcp.proc
16431 0.0% 0.0% 0.0% cdp2.iosproc
114738 0.0% 0.0% 0.0% tftp_fs.proc
Don't ping from the box as the packet will be processed by the CPU.
Do your test from devices sitting behind the box, don't stress the box with pings or any other communication tool.
In some circumstances, even a simple show run can cause a spike in the CPU.
HTH,
__
Edison.
Many MLS devices, such as a 6500, use special hardware to deliver their high perfomance for moving traffic through the device. Any processing that's not supported by their special hardware is processed on some kind of general processor which often can not deliver the same level of high performance. Using a network device as a host device, such as generating pings or responding to pings, are often functions not supported by their special hardware and may cause their CPU to spike.
Hello everybody,
I have a high cpu utilization problem too. I have a Cat6509 with Sup32-PISA-10GE and when I upgraded from 12.2(18)ZY2 to 12.2(18)ZYA and switch booted, the following process was utilizing CPU at 99%:
140 3426368 21182 161758 99.92% 99.53% 99.53% 0 Xscale Sibyte Co
I reloaded again and now all seems to be OK.
Does anyone know what could have happened?
You may be hitting a bug, can you backrev to ZY2 and see if you can reproduce it?
__
Edison.
Gotta be a bug. We installed brand new switches and everyone is doing the same thing. Rebooting clears it up. Same Version, Same Process.
