Help with the Total translations field (0 static, 2 dynamic; 0 extended)... what does extended mean?
santoshbajimaya
Hello guys,
While using the NAT, the "show ip nat traslations" shows output as:
Total translations: 2 (0 static, 2 dynamic; 0 extended)
I wanted to know what does those field mean; especially the "extended"field.
Mark Malone
Its stating there have been 2 dynamic translations in NAT on your router, the extendable is used for address translation when you have the same local internal ip address being mapped to multiple ips , you use the extendable command to allow this to happen
This link explains it well with an example
https://networklessons.com/uncategorized/nat-extendable-on-cisco-ios/
Mark Malone
