Hidden commands
I heard that IOSes have some Hidden Commands.is it true?
If it is true, how can I find and use them<
click on the link below for a listing of hidden IOS commands. You use them just like ´normal´ IOS commands, you just don´t see them when you type a ´?´ at the command prompt...
Undocumented Cisco IOS Router Commands
http://www.tech-forums.net/computer/topic/28883.html
HTH,
GP
Hi also try "DOTU" (Document the undocumented, http://boerland.com/dotu/), where you will find a list of commands as well as short descriptions.
Martin
thisisshanky
Level 11
Level 11
Reza,
Please note that, most of these commands are undocumented, which means you may or may not be able to understand the impact of that command on a working production system. Use hidden commands (atleast of some of them) with utmost care!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
