10-25-2013 02:54 PM - edited 03-07-2019 04:14 PM
A Catalyst 3850-24P runs IOS-XE 3.2.2SE is reporting what seems like excessively high rates of CPU utilitization.
There is no debugging enabled at this time.
The busiest process seems to be 'fed'
k390-cal-r-4a-0#show proc cpu sorted
Core 0: CPU utilization for five seconds: 59%; one minute: 53%; five minutes: 55%
Core 1: CPU utilization for five seconds: 56%; one minute: 58%; five minutes: 64%
Core 2: CPU utilization for five seconds: 45%; one minute: 54%; five minutes: 59%
Core 3: CPU utilization for five seconds: 87%; one minute: 86%; five minutes: 72%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5576 1507975 10740467 167 51.59 52.54 51.83 1088 fed
9123 1448242 25838224 186 8.53 7.38 7.03 0 iosd
6084 1746809 15059128 63 1.45 0.99 0.96 0 pdsd
5577 852155 83677404 11 0.14 0.10 0.09 0 platform_mgr
What is the purpose of the 'fed' process? Why is it so busy? Should we be concerned?
On the 3850, are all four CPU cores treated as equal resources? Is load on any one core significant and something to be watched for? Which core is the most important one?
At present this switch is serving as a router for two stacks of access layer switches (a total of about 300 users.) The only ports in use are on the C3850-NM-4-1G (one uplink, two downlinks.)
10-25-2013 10:29 PM
No debugs running? There was a similar post here:
https://supportforums.cisco.com/thread/2212348
Seems this platform has some CPU load usually.
Daniel Dib
CCIE #37149
12-10-2013 12:45 PM
Was there ever a posted Fix for this? I seem to be experiencing the same thing and no debugging is turned on.
12-11-2013 05:24 AM
Further investigation at the time of the originally reported event revealed that forwarding of payload traffic was impaired for a most (but not all) end-users. The solution was to reload the switch stack.
Subsequently, we have noticed the same symptoms occurring in two other stacks of 3850's. Reloads cured them as well.
Root cause is still unknown. Our operations team now knows this as the 'insane router' syndrome.
12-11-2013 05:31 AM
Thanks for the update! When you Reloaded the stacks did you upgrade them to 3.3.0SE or leave them at 3.2.2SE?
Any changes in the reload - i.e. turn off nmps?
12-11-2013 05:40 AM
So far we have made no changes to software version nor to configuration.
