High CPU Interrupt Rate on 7206vxr
Nidal Safadi
Hello Everybody;
I had a very stange problem we suffer from serveral months, searching all internet sites disccusions with no luck to get a solution, here are the details:
I'm a service provider which provide ADSL service, we have 5 LNSs "BRAS" to terminat PPP users via LAC of Upper service provider.
Each LNS type is Cisco 7206vxr-NPE-G2 ( c7200p-adventerprisek9-mz.151-4.M1.bin ) handle 1800 PPP sessions and also each LNS connected to 13 LAC via vpdn over l2tp tunnels, and each LNS handle (400 - 500 Mbps) of traffic which make total of 2.5 Gbps to Internet Router.
LNS configuration not include any additional configuration else it runs OSPF to collect connected routes and send it to Internet Router.
The problem is we suffer from High cpu utlization of Interrupts. Each LNS have CPU rate of : 90/70.
Please could any one give me any advice to solve this or it's a normal thing?
Note: ip cef enabled
i can provide you any show results
Here some of show results:
LNS#show cef drop
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [feature]'
IPv4 CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP             0           0  2562691697          90           0       12160
LNS#show cef not-cef-switched
IPv4 CEF Packets passed on to next switching layer
Slot  No_adj No_encap Unsupp'ted Redirect  Receive  Options   Access     Frag
RP         0       0  2562929756        0 68566096        0   126945        0
LNS#show interfaces switching
GigabitEthernet0/1 " Interface face upper service provider "
          Throttle count          0
                   Drops         RP        176         SP          0
             SPD Flushes       Fast     471823        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    1924470      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process  718302296 4126662098 1112298943 1451433415
            Cache misses          0          -          -          -
                    Fast 3305818606 1149552345  661100592 1370347133
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0       1738     133826
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       4780     286800       1526      91560
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process      17399    8247126      19362    7163940
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0     104308    6258480
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
GigabitEthernet0/2 " Inerface connected to Internet Router "
          Throttle count          0
                   Drops         RP     959104         SP          0
             SPD Flushes       Fast   15007215        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    1364797      Drops          0
    Protocol  IP
                 Process  999401649 1612699701  712502786 2118640235
                    Fast 1083143063 4057627019 3036792652 3002157150
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process         75       4500       1254      75240
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  CDP
                 Process      19355    8245225      19354    7160980
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0     104314    6258840
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Some of Virtual-Access Users result:
Virtual-Access10
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs      25451      Drops          0
    Protocol  IP
                 Process     385798   16849653     457847  635790618
                    Fast     681084   63626366   26634169 1192416118
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          3         96      86610    1386434
                    Fast   19576850 2329991433          0          0
               Auton/SSE          0          0          0          0
Virtual-Access12
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       8543      Drops          0
    Protocol  IP
                 Process      15848    8018299      21948    2215706
                    Fast     310092   46529741   22224211 1403568072
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          4        128      85123    1362688
                    Fast   17113093 2030440478          0          0
               Auton/SSE          0          0          0          0
Virtual-Access19
          Throttle count          0
                   Drops         RP          0         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       8123      Drops          0
    Protocol  IP
                 Process    1637093  139266284    2423448 3162258987
                    Fast          0          0   28885932 2671057232
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0      85303    1365572
                    Fast   20771820 2246068842          0          0
               Auton/SSE          0          0          0          0
LNS#show ip cef switching statistics
Path   Reason                          Drop       Punt  Punt2Host
RP LES Packet destined for us             0   35893991          0
RP LES TTL expired                        0          0        170
RP LES Fragmentation failed, DF         389          0          0
RP LES Features                     9615849          0          0
RP LES Unclassified reason                9  997284686          0
RP LES Neighbor resolution req            0          1          0
RP LES Fragmentation no pak               0          0       3441
RP LES Total                        9616247 1033178678       3611
RP PAS No route                          90          0          1
RP PAS Packet destined for us          2919   32696467        216
RP PAS Incomplete adjacency           21772          0          0
RP PAS Bad checksum                   12161          0          0
RP PAS TTL expired                        0          0   11118798
RP PAS Bad IP packet length              37          0          0
RP PAS Features                   964811261  557882479     131388
RP PAS Unclassified reason           294249  997284686          0
RP PAS Neighbor resolution req            1          0          0
RP PAS Total                      965142490 1587863632   11250403
All    Total                      974758737 2621042310   11254014
2 seconds after another show command
RP LES Packet destined for us             0   35894734          0
RP LES Features                     9615935          0          0
RP LES Unclassified reason                9  997291274          0
RP LES Fragmentation no pak               0          0       3442
RP LES Total                        9616333 1033186009       3612
RP PAS Packet destined for us          2919   32696508        216
RP PAS TTL expired                        0          0   11118890
RP PAS Features                   964819941  557889345     131389
RP PAS Unclassified reason           294250  997291274          0
RP PAS Total                      965151171 1587877127   11250496
All    Total                      974767504 2621063136   11254108
LNS#show ip cef switching statistics feature
IPv4 CEF input features:
Path   Feature                Drop    Consume       Punt  Punt2Host Gave route
RP LES uRPF                     17          0          0          0          0
RP LES CAR                   74919          0          0          0          0
RP PAS Virtual Fragment      54857    6440840          0       4470          0
RP PAS Access List          117919          0          0     126642          0
RP PAS uRPF                 247018          0          0          0          0
RP PAS CAR                11870139          0          0          0          0
Total                     12364869    6440840          0     131112          0
IPv4 CEF output features:
Path   Feature                Drop    Consume       Punt  Punt2Host    New i/f
RP LES CAR                 9541552          0          0          0          0
RP PAS Access List          415655          0          0        303          0
RP PAS TCP Adjust MSS            0          0  557939001          0          0
RP PAS CAR               952181909          0          0          0          0
Total                    962139116          0  557939001        303          0
IPv4 CEF post-encap features:
Total                            0          0          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
LNS#show ip traffic
IP statistics:
  Rcvd:  1731030398 total, 29323905 local destination
         7 format errors, 230 checksum errors, 9755726 bad hop count
         0 unknown protocol, 0 not a gateway
         0 security failures, 0 bad options, 9238659 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 9238659 alert, 0 cipso, 0 ump
         0 other
  Frags: 9717546 reassembled, 6040 timeouts, 0 couldn't reassemble
         443666552 fragmented, 887330011 fragments, 778 couldn't fragment
  Bcast: 90024 received, 0 sent
  Mcast: 1362936 received, 685736 sent
  Sent:  154123399 generated, 1231263328 forwarded
  Drop:  913 encapsulation failed, 0 unresolved, 0 no adjacency
         0 no route, 250302 unicast RPF, 0 forced drop
         0 options denied
  Drop:  0 packets with source IP address zero
  Drop:  0 packets with internal loop back IP address
         0 physical broadcast
  Reinj: 0 in input feature path, 0 in output feature path
ICMP statistics:
  Rcvd: 0 format errors, 147 checksum errors, 0 redirects, 22 unreachable
        104596 echo, 2 echo reply, 0 mask requests, 0 mask replies, 0 quench
        0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        10662 time exceeded, 0 info replies
  Sent: 0 redirects, 132461 unreachable, 0 echo, 104596 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
        0 info reply, 188205 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 25409 total, 3 checksum errors, 59 no port
  Sent: 24035 total
BGP statistics:
  Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
        0 keepalives, 0 route-refresh, 0 unrecognized
  Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
  Rcvd: 0 total
  Sent: 0 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 27819278 total, 0 checksum errors, 83282 no port
  Sent: 152988495 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 1363785 total, 0 checksum errors
        110059 hello, 172 database desc, 1 link state req
        1113254 link state updates, 140294 link state acks
  Sent: 685982 total
        110015 hello, 173 database desc, 52 link state req
        285043 link state updates, 290701 link state acks
ARP statistics:
  Rcvd: 30911 requests, 365 replies, 0 reverse, 0 other
  Sent: 370 requests, 34367 replies (0 proxy), 0 reverse
  Drop due to input queue full: 0
443666552 fragmented, 887330011 fragments and reassembled Increases Hevaily in IP Statistics
interface Virtual-Template1
ip unnumbered GigabitEthernet0/1
ip access-group denysomething out
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip virtual-reassembly in
ip verify unicast reverse-path
ip tcp adjust-mss 1436
no logging event link-status
peer default ip address pool ADSL-POOL
no ipv6 redirects
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
ppp ipcp dns xx.xx.xx.xx xx.xx.xx.xx
ppp ipcp wins reject
end
Thanks !! waiting for your experience to solve with me this problem.
16 Replies 16
Dr.X
Level 2
Level 2
Plz post relative commands relate to routing on each of lns and 2nd router
The static routes & ospf
& sh ip protocols
any news ?
plz post
sh run | i ip route
at the edgeR router
regards
