High CPU utilization in 6513 core switches
hebaelshahat
we have two 6513 core switches redundant to each other by using HSRP and MST. Currently we have a problem in a CPU as it's high in both cores as appeared in the following logging message:
1: 04/09/12 16:06:20    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): netint_thr_active[1].
  2: 04/09/12 16:04:27    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): RP CPU is busy (94% util).
  3: 04/09/12 15:58:38    7/-1: MAJ, GOLD,
  4: 04/09/12 15:57:18    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): RP CPU is busy (100% util).
  5: 04/09/12 15:42:22    7/-1: MAJ, GOLD,
  6: 04/09/12 15:38:34    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): RP CPU is busy (81% util).
  7: 04/09/12 15:37:10    7/-1: MAJ, GOLD,
  8: 04/09/12 15:20:22    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): RP CPU is busy (96% util).
  9: 04/09/12 15:18:40    7/-1: MAJ, GOLD,
test_sp_rp_inband_ping[7]: diag_hit_sp_sys_limit. SP-RP Ping Test skipped. Reason(s): RP CPU is busy (97% util).
Could you Please advise the reason of that.
Attached is the output of the "show processes cpu"
Pulkit Nagpal
Hello Heba,
The CPU is high because of Interrupt. You might want to check this page for guidance:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml#situations
Also, this document which teaches you how to capture traffic going to CPU:
https://supportforums.cisco.com/docs/DOC-15608
Hope this helps,
Pulkit
Thanks a lot Pulkit for your reply, I'll check them and feed you back.
Hello Heba, could you please tell me if find a solution for this issue?. In this moment i have a similar problem.
Best regards from Chile!
