HIGH CPU UTILIZATION OF 4500 SWITCH
Sunil Patil
I have one Cisco 4500 switch. On that switch we are facing high CPU intermittently. CPU utilization is reaching 80% from last one week, no changes been done. For reference i am attaching the Show log output. But I am unable to capture the show process cpu output because whenever I logged in the device for capture the output the CPU process gone down.
I also get the error of %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET in show logs. But I checked for same that there is no hub is connected in that switch.
ranjit123
Level 3
Level 3
Hi!,
Shut VLAN 212 your problem will be solved.
Ranjit
But about the trafiic of VLAN 212.
Check the source of the MAC address
do u have VMWARE or multicasting enabled in your N/W that is connected to your core switch.
Your core switch is not able to process the request
show process cpu will be more helpfull here
Ranjit
