High CPU utilization on 3650
lertasnet
I have noticed that our cpu jumped from 10% to 30% instanlty and 2 days ago from 30% to 50%
Below the output:
Core 0: CPU utilization for five seconds: 77%; one minute: 83%;  five minutes: 83%
Core 1: CPU utilization for five seconds: 20%; one minute: 30%;  five minutes: 31%
Core 2: CPU utilization for five seconds: 14%; one minute: 54%;  five minutes: 45%
Core 3: CPU utilization for five seconds: 88%; one minute: 34%;  five minutes: 42%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
5669   3536943     21414829 270    25.74    25.44    25.46    1088  fed
6155   4254245     40425480 93     21.06    21.28    21.26    0     pdsd
8533   2769521     11307085 155    3.18     3.23     3.18     0     iosd
There is no debugs running, no L3 routing only L2 switching
Nothing has changed in the network when the cpu jumped...
Cant find any posts for pdsd that can explain why it is so high.
Below the switch version output
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3650-24TS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO1815Q0FJ
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : xxxxxxxxxxxxxx
Motherboard Assembly Number        : 73-15127-05
Motherboard Serial Number          : xxxxxxxxxxx
Model Revision Number              : A0
Motherboard Revision Number        : A0
Model Number                       : WS-C3650-24TS
System Serial Number               : FDO1815Q0FJ
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    WS-C3650-24TS      03.03.03SE        cat3k_caa-universalk9 INSTALL
Any help would be greatly appreciated!
Lefteris
5 Replies 5
can you please print  "show proc cpu detailed fed | ex 0.0" and "show proc cpu detailed psds | ex 0.0".
It seems that you've traffic being punted to the CPU.
See if this document helps:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117594-technote-hicpu3850-00.html
BR.
CORE-SW01#show proc cpu detailed process fed | ex 0.0
Core 0: CPU utilization for five seconds: 80%; one minute: 80%; five minutes: 83%
Core 1: CPU utilization for five seconds: 16%; one minute: 18%; five minutes: 25%
Core 2: CPU utilization for five seconds: 9%; one minute: 19%; five minutes: 23%
Core 3: CPU utilization for five seconds: 95%; one minute: 83%; five minutes: 69%
PID     T C  TID     Runtime(ms) Invoked   uSecs  5Sec   1Min 5Min TTY   Process
5669    L            3355375     217008429 272    25.7   25.4 25.4 1088  fed
5669    L 1  6104    349238      316146804 0      0.24   0.16 0.15 0     fed-ots-main
5669    L 1  6107    2932230     22575463  0      0.24   0.24 0.24 0     fed-ots-nfl
5669    L 3  9032    3476486     133166435 0      23.8   23.7 23.8 0     PunjectRx
5669    L 0  9033    672117      114199372 0      1.05   0.88 0.81 0     PunjectTx
AND
CORE-SW01#show proc cpu detailed process pdsd | ex 0.0
Core 0: CPU utilization for five seconds: 86%; one minute: 80%; five minutes: 82%
Core 1: CPU utilization for five seconds: 13%; one minute: 26%; five minutes: 33%
Core 2: CPU utilization for five seconds: 8%; one minute: 61%; five minutes: 32%
Core 3: CPU utilization for five seconds: 94%; one minute: 35%; five minutes: 54%
6155    L            3748054     404995635 100    22.1   21.5 21.6 0     pdsd
6155    L 0  8451    700898      353312874 0      22.1   21.5 21.6 0     pdsd
Thanks!
You need to check the traffic that is being punted to the CPU. In the document that I sent you in the last post describes the way to capture some of this traffic, that way you can understand what is causing the high CPU.
Hi Norberto,
Thanks for the tip. I followed the steps on the link you sent me.
I discovered that the cpu is affected by a lot of arp requests coming from our edge device.
We have 16 /24 ranges with the edge device(s) being the gateway(s)
A lot of those IP addresses are vacant and when executing sh arp, we see a lot of incomplete mac addresses for those vacant IPs (expected)
The real question now is:
Why cant the switch handle those arp requests with a lower cpu load?
Is there a fix?
I removed some /24 prefixes from the edge devices to eliminate as much as possible the ar requests (this is the DMZ and we are being scanned 24x7) but I see very little improvement on the cpu load... (about 1%) although I did notice that the jumps were happening when ADDING a /24 prefix to the edge devices.
Pls dont tell me to reboot the core! :)
Any ideas? Is this behavior normal? Are we doing something wrong?
Again many many thanks for your support!
BR,
Lefteris
maybe ?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux39490/?referring_site=bugquickviewclick
